Timing marks??????
Old Jul 22, 2017 | 03:41 PM
  #31
OldFords4Life's Avatar
OldFords4Life
Originally Posted by skylermitchell94f350
How do you make a new post? I need help with my 80 f150
https://www.ford-trucks.com/forums/faq.php
Old Jul 6, 2019 | 12:16 AM
  #32
old28's Avatar
old28
I know this is an old thread, but I am pulling it up to ask a question that was not answered in the post. I have 1971 F250 with a 300 4.9L motor. My motor has the correct passenger side timing plate that starts at 6* ATDC and runs to 14* BTDC. I am looking for two new or used plates. Anyone got two that they will sell or does anyone know where I can buy some on the web?
Old Jul 15, 2019 | 11:34 AM
  #33
AbandonedBronco's Avatar
AbandonedBronco
Hi Old28,
Why do you need two?
I have one sitting somewhere in my garage since I pulled it off my engine. I'll probably never use it.
Old Jul 22, 2019 | 10:32 PM
  #34
jrotten67's Avatar
jrotten67
I pulled my 300 to do the rear main and was looking at the timing marks on my engine. I have the marks in the cover and also the saw tooth timing indicator. My damper has 2 small "v" cuts in it that line up on both marks. Did it come this way? From reading this post I didn't see anyone else explain it like what I am seeing
Old Jul 23, 2019 | 09:47 AM
  #35
AbandonedBronco
My original 300 had both the timing cover marks, and the little tooth timing indicator on the passenger side. The pulley had two marks, where each one lined up with one of the indicators. It was really nice.
Personally, I prefer the timing cover marks, since I can reach the distributor and adjust the timing while seeing and holding the timing light on the marks. With the passenger side marks, you have to tweak, walk over and check, walk back and tweak, walk back and check, etc...
Old Jul 16, 2025 | 08:47 PM
  #36
Heiferman's Avatar
Heiferman
Uphill All Day
this thread is worthless without pics!I can't find any marks on my '85 300. I suspect the bolt on was removed by a PO.
Barry McLean
Jul 16, 2025 08:45 PM
Hobb
16
Sep 6, 2017 02:51 PM
Matthew_
Sep 4, 2017 04:22 PM
mikec53
Oct 7, 2016 06:39 PM
