Both turn signal flash
Old Jul 12, 2005 | 09:25 PM
Mecheng's Avatar
Mecheng
Red face Both turn signal flash
I have an 85 F-150 truck. It's been so reliable for many years. Recently I have experienced a problem with the right hand turn signal. When I turn it on the right signals flash and so the left ones (front and back) but much dimmer. I replaced the turn signal switch and it did not change a thing. Also the warning buzzer sounds to the blinking of the right turn signal only. I have done no mods to the wiring. I do have nasty corroded looking trailer harness though. Oh, I did have problem with the stop light switch and replaced it with and Advance Auto part. This seems to be about the time I noticed the turn signal problem.
Just finished a firing up my 302HO transplant and very anixous to get the truck back on the road.
Old Jul 13, 2005 | 12:08 AM
minishtr's Avatar
minishtr
Could be the switch or when you replaced it you moved some bad wires around.Check the wiring and the trailer plug.
Old Jul 13, 2005 | 01:16 AM
220k-f-150's Avatar
220k-f-150
Check grounds, sounds like its using other light to ground out. Check that trailer harness too.
Check those bulbs and sockets too. Front and back for corrsion bad wire and such.
Old Jul 13, 2005 | 06:47 AM
Mecheng's Avatar
Mecheng
Yep, now that I found the color coded wiring diagram I think I will start with turn signal multifunction switch. I will disconnect the left hand blinker wires at the connector under the dash from the turn signal switch and determine if this "current leakage" is at the switch or downstream. It's a new Wells switch too. I'd be surprised if it's bad but who knows.
Old Jul 13, 2005 | 09:48 AM
cokeman's Avatar
cokeman
Active Streak: 30 Days
Active Streak: 60 Days
It's definitely a grounding problem. Before you spend too much time testing the switch, take 220k's advice and check all the grounds first.
Old Jul 13, 2005 | 11:06 AM
stuart1's Avatar
stuart1
Have a good look at the bulbs. They are double filament and if one breaks it can fall onto the other one and cause a feed back.
Old Jul 13, 2005 | 11:41 AM
Franklin2's Avatar
Franklin2
I too vote a grounding problem. I would also fix the obvious trailer wiring problem. All your signals go there to, so it could get crossed up if it's in really bad shape. If you do not have time to repair it, just cut it out and tape the wires off till you get a chance to put a new one on.
Old Jul 14, 2005 | 07:03 AM
Mecheng's Avatar
Mecheng
Thanks fellas you hit it right on. It was the trailer wiring with a bad ground. I disconnected the mess repaired the ground wire and everything works normal now.
Rudog
Nov 15, 2012 12:35 PM
R7d7ta
1997 - 2003 F150
Feb 20, 2011 01:14 PM
undertakerman
Sep 5, 2010 12:52 PM
barefootstu
Electrical Systems/Wiring
18
Jan 28, 2007 12:42 PM
