cruise and horn doesn't work
Old Jul 12, 2005 | 06:33 PM
rodolan's Avatar
rodolan
Talking cruise and horn doesn't work
I've just purchased a used 2002 crew cab 4x4 powerstroke and the horn and cruise don't work I've checked fuses and they're ok any suggestions would be appreciated. By the way I'm new here only my second post..Thanks
Old Jul 12, 2005 | 07:15 PM
JOE-M's Avatar
JOE-M
If you are sure the fuses are good, maybe take the cover off of the steering column and see if you have broken wires there.
Welcome to the site. You will meet the nicest and most knowlegeable people here. (sorry but I'm not one of them
Joe
Old Jul 12, 2005 | 07:21 PM
rodolan's Avatar
rodolan
Talking
Joe m I removed air bag to look underneathand all wires look ok sorry I forgot to mention this in first post.......
Old Jul 12, 2005 | 07:31 PM
JOE-M's Avatar
JOE-M
Did you take a test light and see if you have power to them? I would still remove the column cover and check where the wires rub when you turn the wheel. You are a braver man than I am if you'll mess with the air bag. I would be affraid that sucker would go off in my face.
Joe
Old Jul 12, 2005 | 08:01 PM
Ed 4X2X's Avatar
Ed 4X2X
you might want to test where the fuse sets into also to see if the juice is flowing there also.......
Old Jul 12, 2005 | 08:08 PM
mdp49's Avatar
mdp49
I had a '94 Ford that a broken clockspring in the steering column caused the cruise and horn not to work. Just a place to look???
Old Jul 12, 2005 | 09:08 PM
rodolan's Avatar
rodolan
Talking
I'll check in the morning to see if I have current and also check clockspring. p.s. I disconnected battery and was very cautious when removing airbag..Rodney
Old Jul 12, 2005 | 09:23 PM
77hiboyboy's Avatar
77hiboyboy
is the airbag light going off??
Old Jul 12, 2005 | 09:33 PM
rodolan's Avatar
rodolan
No the airbag lites up at start up then goes off......
Old Jul 13, 2005 | 06:14 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 13, 2005 | 11:13 PM
Mcol's Avatar
Mcol
Not sure if this fits you or not but there are fused in the dash and under the hood. Some of the ones under the hood are Maxi fuses (bigger fuses). This is where I found the fuse for my cruise and back up light there and it was blown.
Hope this helps.
Jimmy
Old Jul 15, 2005 | 04:51 PM
rodolan's Avatar
rodolan
Talking
well I've got horn and cruise working . First of all I did'nt have owner's manual, so I went to dealer and got printout of cruise and horn schematics and fuse #'s turns out manual shows fuse that wasn't in printout .To make long story short fuse was burnt ,tracked down one of the dual horns was not working causing fuse to blow. Now cruise and horn both work..Thanks a whole bunch for all the posts...............Rodney
Old Jul 15, 2005 | 07:01 PM
JOE-M's Avatar
JOE-M
Good deal! Glad to hear it.
Joe
Old Feb 3, 2007 | 09:58 PM
bigtexan99's Avatar
bigtexan99
My cruise and horn are not working either. Do you remember which fuse number it was?
I noticed that under the steering wheel, I am missing relay #3. The owners manual says that is for the horn. Does anyone know what size or part number relay that should be?
Thanks!
Old Feb 4, 2007 | 12:40 PM
rodolan's Avatar
rodolan
My truck was an 02 and I don't remember which fuse it was but it was one in the fuse box, they had two fuses for the horn if I remember right. sorry can't be of more help..........
SpectreZ91
Jul 14, 2021 10:35 PM
ivory-tower
Aug 22, 2011 07:26 PM
depotops
May 19, 2010 12:06 PM
Ripbc
Nov 5, 2006 03:27 PM
oskie
Jan 27, 2006 12:38 AM
