94 F350 Drivetrain Fluids
Old Jul 12, 2005 | 04:54 PM
Timberwerks's Avatar
Timberwerks
I just bought a 94 F350 at auction and have no manual to refer to. Can someone tell what fluid types I should use for the transmission,transfer case and diffs. The trany is a manual 5 speed so I assume a 80/90 gear lube will be ok for that. The tranfer case is a Borg Warner and I am unsure if it uses Dextron or the same above gear lube. How about the diff's?
Thanks
Dale
Old Jul 12, 2005 | 05:35 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jul 12, 2005 | 06:18 PM
mdpnh's Avatar
mdpnh
Dexron/Mercon for tranny and T-case. 89/90 gear oil for diffs. Incidentally, type F ATF for Power steer, or power steer fluid.
Old Jul 13, 2005 | 11:31 AM
Timberwerks
Thanks for the welcome and replies. Is the Dexron/Mercon an automatic transmission fluid? If so how come a manual would use it? Sorry for the dumb question. This is my first Ford truck so I'm sure I'll have more questions down the line. I'm looking forward to getting another Ford in the next year or so.
Dale
Old Jul 13, 2005 | 12:09 PM
mdpnh's Avatar
mdpnh
Yes, It is an Automatic Transmission Fluid. ATF has been standard fare for manual transmissions and transfer cases for 10-15 years now. It has a lower viscosity and therefore offers less oil drag on the gears. Translation: Better gas mileage. Probably gives better cooling and contaminant dispersion as well. I'm not sure about that so if someone else knows for sure just let us know. Wouldn't want to be putting out bad info.
Gear619
Feb 23, 2015 11:06 PM
RIKIL
May 25, 2012 04:36 PM
wantaford
May 11, 2010 10:43 PM
landon460
Jul 13, 2009 05:11 AM
