Swapping Instrument Cluster Q?
Old Jul 13, 2005 | 02:05 AM
93nighthawk's Avatar
93nighthawk
Hi,
When you swap an instrument cluster in an early-mid '90s F-150, does the true millage on the vehilce show on the digital odometer, or the millage of the donor cluster? If it does show the donor cluster millage, is there some way to get around it? (installing your original digital odometer? And will that cause an (E) in it?)
Also is the speedo run by cable or PCM?
Are there any other pitfalls that I should keep an eye out for?
I am looking at maybe swapping out my non-tach cluster to a cluster w/ tach.
Old Jul 13, 2005 | 12:23 PM
charlez's Avatar
charlez
The mileage is stored in the cluster so the donor mileage would show. This is easy, just swap the speedo/odo out. The speedo is run from the abs sensor located on the rear axle.
Here is an article I wrote up a few years back that outlines this swap.
Installing OEM Tach in 92-96 F-Series / Bronco
Old Jul 13, 2005 | 12:37 PM
quicklook2's Avatar
quicklook2
that was an excellent article, thanks!
Old Jul 13, 2005 | 12:51 PM
93nighthawk
I agree! Very informative and helpful. Thanks for helping the community out charlez.
Now as soon as I get my hands on a cluster w/ tach, we will see if this swap works for the Aerostar/E-seriers dash's too.
