what fluid do I use
Old Jul 12, 2009 | 01:27 PM
landon460's Avatar
landon460
what fluid do I use
My Borg Warner 4407 T-case in my 96 F-350 likes to stick between gears and just click while the truck is moving. I believe it's because it's low on fluid so is there a special type of fuid I should be using?
Old Jul 12, 2009 | 01:40 PM
BucksTrucks's Avatar
BucksTrucks
Good ole ATF, Mercron is recommended but I dont see how type F could hurt it.
Old Jul 12, 2009 | 05:20 PM
landon460's Avatar
landon460
Think that the low fluid is causing it to no go all the way in gear? The linkage seems fine I replaced the linkage only like 1 1/2 years ago.
Old Jul 12, 2009 | 05:39 PM
BucksTrucks
Its possible but I'm not sure. If the fluid wasn't really really low I don't think it would do any internal damage. I would double check the linkage before I go suspecting the transfer case. But if it is these things are everywhere at junk yards, a replacement shouldn't be hard to come by.
Old Jul 13, 2009 | 05:11 AM
landon460's Avatar
landon460
not around here
I have not seen one single BW4407 T-case in the junk yards in my area. Where are you from?
Walleye Hunter
Jun 14, 2014 09:02 AM
abyars111
Apr 16, 2013 05:36 PM
crivaro
Aug 4, 2011 11:24 AM
brian.taylor
Sep 30, 2006 01:52 AM
td351w
Aug 28, 2002 01:32 PM
