Does it occur during a certain speed range at all, or any time you accelerate? Do you get it with steady throttle at any given speed? Is it a loud whine or faint sound? Ringing or gear meshing sound? Has the rear differential been removed from the axle for any reason recently?
I'm gonna take a WAG and speculate that you're ring and pinion gears have developed a whine. It happens, and if it doesn't get worse then its probably harmless. But it could also indicate that something has changed within the axle and may warrant attention...
how many miles on rear end oil since last change?
any leaks or seeps around pinion shaft seal on front?
been driving through deep water in past several months, more than 6 inches.
since it is easy quick service, I would pull cover, drain and check condition of oil, any foaming or water mix. check for metal cuttings in bottom of drain pan, on fill plug magnet and in bottom of housing.
check ring and pinion teeth for smooth even wear pattern. have someone rotate tire while listening to and observing ring and pinion for any unusual noise or movement.
new synthetic hypoid 70w90 with Lubeguard low friction additive. Aero rear ends love synthetic hypoid, mine is so quiet the wife even commented.
It Has Been About 10000 Miles Since Last Oil Change In Diff There Was No Metal Then Just Normal Wear No Leaks Around Pinion Seal
No Water Or Seaping The Noise It A Acc Its A Constant Noise Like It
Is A Wheel Bearing But It Is Not Checked Them When You Coast The
Noise Leaves ? It Had The Drive Shaft Replaced Under A Tsb To The Allu One What Do You Think Bad U Joint ? Mabey Il Pull The Shaft And Check The U Joints
I apologize for my wise a** reply, only that I was the first thought that went through my mind. Thanks for having a sense of humor, as was my intention...Ed
