Aerostar Ford Aerostar
Rear Diff Noise
Old Jul 10, 2005 | 11:22 PM
jddowell's Avatar
jddowell
Rear Diff Noise
Latley when i drive i here a whine from the rear end only on acc and not at a coast any ideas
Old Jul 11, 2005 | 12:35 AM
93nighthawk's Avatar
93nighthawk
Welcome!
how old are the rear brakes? Does the E-brake stick?
You can always pull the pan and check the internals for wear/damage.
Old Jul 11, 2005 | 08:23 AM
jddowell's Avatar
jddowell
Cool Rear diff
New Brakes No Stiching E Brake And No Visiable Ware Just The Noise
Old Jul 11, 2005 | 08:31 AM
Torsen Rick's Avatar
Torsen Rick
Does it occur during a certain speed range at all, or any time you accelerate? Do you get it with steady throttle at any given speed? Is it a loud whine or faint sound? Ringing or gear meshing sound? Has the rear differential been removed from the axle for any reason recently?
I'm gonna take a WAG and speculate that you're ring and pinion gears have developed a whine. It happens, and if it doesn't get worse then its probably harmless. But it could also indicate that something has changed within the axle and may warrant attention...
Old Jul 11, 2005 | 03:19 PM
96_4wdr's Avatar
96_4wdr
how many miles on rear end oil since last change?
any leaks or seeps around pinion shaft seal on front?
been driving through deep water in past several months, more than 6 inches.
since it is easy quick service, I would pull cover, drain and check condition of oil, any foaming or water mix. check for metal cuttings in bottom of drain pan, on fill plug magnet and in bottom of housing.
check ring and pinion teeth for smooth even wear pattern. have someone rotate tire while listening to and observing ring and pinion for any unusual noise or movement.
new synthetic hypoid 70w90 with Lubeguard low friction additive. Aero rear ends love synthetic hypoid, mine is so quiet the wife even commented.
Old Jul 11, 2005 | 11:31 PM
jddowell's Avatar
jddowell
Unhappy Rear Diff
It Has Been About 10000 Miles Since Last Oil Change In Diff There Was No Metal Then Just Normal Wear No Leaks Around Pinion Seal
No Water Or Seaping The Noise It A Acc Its A Constant Noise Like It
Is A Wheel Bearing But It Is Not Checked Them When You Coast The
Noise Leaves ? It Had The Drive Shaft Replaced Under A Tsb To The Allu One What Do You Think Bad U Joint ? Mabey Il Pull The Shaft And Check The U Joints
Old Jul 11, 2005 | 11:42 PM
93nighthawk
Did this just happen after the brake job. If so, I think they swapped the front and rear shoes around and your rear end is dragging.
Old Jul 12, 2005 | 03:57 AM
Ed's Avatar
Ed
Does the whine noise stop after the small children are removed from the back row seats?
Old Jul 12, 2005 | 09:16 AM
jddowell's Avatar
jddowell
Smile Whine
It Stopped About 10years ago Ed they grew up
Old Jul 12, 2005 | 09:11 PM
obars's Avatar
obars
I had a 1990 with 3.0, and it whined as long as I owned it. Changed oil, still the same. I finally just installed bigger rear speakers...
Old Jul 13, 2005 | 02:36 AM
Ed's Avatar
Ed
I apologize for my wise a** reply, only that I was the first thought that went through my mind. Thanks for having a sense of humor, as was my intention...Ed
Old Jul 13, 2005 | 08:36 AM
jddowell's Avatar
jddowell
Talking rear diff
its all good ed i thought it was funny to that why i wrote that little line to you have a good day
streaksf
2004 - 2008 F150
Nov 29, 2012 03:34 PM
dillinewton
Offroad & 4x4
49
Mar 1, 2010 09:52 AM
Maddog521
Escape & Escape Hybrid
Aug 25, 2008 09:23 AM
