2" lift on the front of an F-100 (gotta be only 2"!)
I have a 2WD '74 F-100 (coil springs) that need to have the front lifted EXACTLY 2" to accomodate my new larger wheels and tires (285-60-18).
I know its only a measley 2WD right now, but I thought I would consult the experts on lifts in this forum. The thing is, it can't be any more than 2" of lift and it can't mess up my fresh front-end alignment. Where can I get 2" for the front?
There's no way in the world that you can do a suspension lift on a twin I beam or twin traction beam without camber adjustment/correction. You could lower the beam pivots exactly 2" but you're still going to be off because there isn't a coil spring out there that will give you exactly 2" of lift. If you're totally adamant about 2" without re-aligning, then put a body lift on it.
Cody
Cody
The truck I have has a 300 I-6 in it. Could I put in a set of coils from a V8 (460?) and get the correct results? If it is too much of a lift, I suppose I could cut a coil off, right?
If push comes to shove, I suppose I can go get it aligned again (cheaper than new tires). I just don't want some convoluted, epic tale just to get a little clearance up front...
Cody
Cody
I dont care, my truck still looked like a low rider even with new shocks, so i decided to blow a whole 50 bucks on a body lift, and it looks a lot better. I didn't feel like dropping money for new coils and leafs on the heap of garbage!
Apparently, Moog offers a "stock" set of springs for these 2wd rigs (replacement springs are apparently hard to find nowadays) that may bring it up to the "as new" stock ride height (whatever that was).
A 31 year old truck is bound to have lost some spring in it's springs...
OTOH, there is this Ebay auction#: 7912154818
Could I just pick these up and install them w/o any other caster/camber/fitment problems? What are your thoughts?
