VIN info help
Old Jan 4, 2003 | 02:56 PM
oldtrapper's Avatar
oldtrapper
VIN info help
I have a 79 F150 I need some help to find out the specs on. On the driver side is a sticker shows made 03/79 VIN # F15JLEG9709 front axle axle rated 3300 lbs. Rear axle rated 3580. A 429 four barrel carb amd c6 in it now. It has front sway bar on it. I/ve never noticed this on this model truck before. It has super cool radiator PS PB A/C tilt dual fuel tanks. Can anyone help with if this is a heavy duty suspension w/sway bar. Code in lower left is FC271. Below this is TO507. I think this originally came with a 460.
Thanks
Oldtrapper
Old Jan 4, 2003 | 03:00 PM
fordguy76's Avatar
fordguy76
VIN info help
[updated:LAST EDITED ON 04-Jan-03 AT 04:03 PM (EST)]there is a vin decoder to the right. click on tech articles. then go down the page. it says something like vin # decoder for 70-80 ford trucks. lots of trucks have front sway bars on them i went ahead and looked it up with just the vin. and it did come with a 460 4bbl. there a spaces for axle codes too.
Old Jan 4, 2003 | 03:37 PM
oldtrapper's Avatar
oldtrapper
VIN info help
Thanks for the help. I have my dad's 73 F250 that is heavy duty all the way. It has dual caliper front brakes and larger brakes on the rear than most 250 have. Found out hard way doing back brakes. I for the 79 to swap front end to a 66 for the PS and P Disc Brakes and I figure I'll replace bushings, king pins and re do the brakes and swap springs and sway bar over. The 73 has heavy duty suspension and has a rear sway bar.
Apparently the 78 and 79 models f150 with 460 eng had sway bars as part of heavy duty suspension.
oldtrapper
73 f250
66 f100
66 f100
Old Jan 4, 2003 | 07:37 PM
larryn's Avatar
larryn
VIN info help
Old Jan 4, 2003 | 09:26 PM
Mil1ion's Avatar
Mil1ion
VIN info help
Get the casting numbers off the block(near starter on side of block) and the heads (Just above the exhaust ports on the heads)then post them here.
I have a Rating plate de-coder on my web site.
That de-coder mentioned earlier is Quite limited.
Mine is comprehensive in comparison.
EG9709 denotes Feb or March 79 <>The 9709th Truck off the line
at the Michigan truck plant.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
oldtrapper
18
Jan 19, 2007 09:00 PM
oldtrapper
Jul 27, 2005 03:42 AM
oldtrapper
Dec 21, 2004 12:02 AM
Boheefus
Oct 6, 2003 04:39 PM
David
Apr 2, 2000 11:07 AM
