Modular V10 (6.8l)
Pinging!!
Old Jul 7, 2005 | 07:57 PM
CBLEGUY's Avatar
CBLEGUY
Pinging!!
I took my truck to the dealership for some low RPM pinging with reg unleaded quik-trip gas (good stuff top tier rated). They replaced the mass airflow sensor, did a fuel injection service, and a computer reporgram. It still pings, just not as bad.. any ideas?
2001 F250 CC SB 4X4 V10 54000miles
Old Jul 7, 2005 | 08:11 PM
boxcar1974's Avatar
boxcar1974
When you say low RPM, are you talking around 1000 to 1200 right before it shifts out of overdrive? If so, I had that in my 03' V10 ever since I drove it off the lot. I know these things are suppose to run on 87 octane. For the longest time I drove around with the overdrive off and it worked fine but MPG suffered. So this I started manipulating the tranny with my foot. When I got to a section af incline in the road that I knew pinging was gonna happen, I just let off the gas for a second and back in.....the tranny would downshift without having to go faster to get it into passing gear. Running a higher octane fuel took that pinging away for me. As of right know I have added a superchips microtuner and I am running 93 octane and it never pings, ever.
Old Jul 7, 2005 | 08:18 PM
CBLEGUY's Avatar
CBLEGUY
It usually does it at about 50mph to 65 in top gear for a very small RPM range. When I put higher octane gas in it, never pings. it is really kind of odd.
S
Old Jul 7, 2005 | 08:36 PM
Five0guy's Avatar
Five0guy
You might want to look into a "top end" cleaning...where a machine is hooked up to your intake (I think) and cleans all of the carbon out of the combustion chamber and piston tops....carbon is the main cause of the pinging you described.
Old Jul 8, 2005 | 08:16 AM
benr0's Avatar
benr0
Try different gas. Mine is fine most of the time on QT gas, but not always. Qt can get its fuel from different sources. Sometimes it has problems.
I have found in my case, the gas makes the difference in pinging or not
Old Jul 8, 2005 | 11:48 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's probably the EGR! The passages get clogged with carbon over time, and the EGR doesn't flow enough.
The EGR is Exhaust Gas Recirculation - it's to reduce the peak combustion temps.
Same thing higher octane gas does
Bring it back to the dealer and tell them about the EGR and maybe they'll give you a break because they didn't figure it out for themselves.
jjurva
Dec 19, 2011 10:17 AM
pursugr
Modular V8 (4.6L, 5.4L)
Sep 28, 2007 05:24 AM
KennethKvittum
1997 - 2003 F150
Jul 9, 2006 02:20 PM
factory594x4
13
Jun 11, 2006 03:13 PM
scottybarrett
Feb 20, 2003 07:13 PM
