table saw slow starting
Old Jul 7, 2005 | 06:10 PM
Avanti's Avatar
Avanti
My old (1983) Sears 9 inch direct drive table saw is slow on starting. It does get up to speed. You have to flipp the switch on a couple of times. Is it the relay or the motor windings? A new motor is the same price as a new 10 inch saw. I like my old cast iron table. The engine rebuilders also want more than the cost of a new saw. Also not sure where the relay is as it is not in the book that came with the saw. Where I can get another motor for less than a $100.00 if the problem is not the relay?
Old Jul 7, 2005 | 06:37 PM
Ford_Six's Avatar
Ford_Six
I don't know about a relay, but usually those motors have an electrolytic capacitor on the side of them. This is used for extra juice on startup, and yours may be dried out. If you can't find a replacement, new motors can usually be found in the Harbor Freight catalogs for pretty cheap. The one in the saw should be a 3/4hp 56 frame motor, pretty standard fare.
Old Jul 7, 2005 | 06:42 PM
Dialtone's Avatar
Dialtone
Not sure about your motor, but I have worked on a couple of pump motors that had the "relay" on the rear end of the motor shaft. Actually, it was a centrifical (sp) weighted contact set that opened/closed depending on the shaft speed. Try removing the rear cover and look it over. May just need lubircating and cleaning if so equipped.
Dialtone
Old Jul 7, 2005 | 06:47 PM
jskufan's Avatar
jskufan
Since you got a lot of years out of the original one, you might try WW Grainger as they might carry a higher quality motor. Like you, my Craftsman saw is one of the heavy duty cast iron table models and I would rather repair it than trade it in for a new model. Check the motor housing for the data plate and it should give you the specs for a replacement motor.
Old Jul 7, 2005 | 07:38 PM
RyanMiller's Avatar
RyanMiller
I work at a electric motor repair shop, and 3 things can cause slow starting.
Bad start capacitor
Dirty switch contacts
dried up sleeve bearings( its a craftsman, so it will most likely have sleeve bearings, they are ALOT cheaper than ball bearings)
So, to rejuvinate your saw motor, take the motor off the saw, take the rear endbell off, blow all the saw dust out of the motor.. then use a dremel to clean the contacts on the start switch, re oil the bearings and give it a shot. If its still not starting right then replace the capacitor.
Old Jul 7, 2005 | 10:16 PM
924x2150's Avatar
924x2150
I can't confirm or deny what the other posters said...don't use a long extension cord, keep the saw as close to the outlet as you can, and use a heavy duty electrical extension cord, the thicker the gauge wires, the better.
Old Jul 7, 2005 | 11:50 PM
nightowl_52's Avatar
nightowl_52
I don't know about any other neck of the woods, but here Grainger only sells wholesale to other businesses.
Old Jul 8, 2005 | 12:06 AM
1bigsteve's Avatar
1bigsteve
Talking
Whats' the motor's AMP rating? I had a 10" Rockwell rated at 15 AMPs and the saw often tripped the circuit breaker and was slow at start-up. A long extension cord will drag the power down. Custom make one. Their easy.
-1bigsteve (o:
Old Jul 10, 2005 | 04:48 PM
Avanti's Avatar
Avanti
table saw
Thanks for all the help everyone. The saw seems to be running ok now. Maybe its because I cleaned it with the air compessor the last time before it starting running slow. I have done it before & not had it run or start slow. I will also run a shorter extension cord to it. I had been running a 25 ft rated for 13 amps. The saw is listed at 10 amps.
66gpw
Jul 11, 2009 11:23 PM
Bob Caygeon
Apr 23, 2008 10:28 PM
scottie2hottie
Feb 2, 2007 10:31 AM
76fordman
Apr 13, 2002 04:12 PM
