Flexplate Identification Help
Old Jul 6, 2005 | 09:11 PM
RaleighDad66's Avatar
RaleighDad66
Can someone tell me how to tell if the flexplate I have is a 28 oz imbalance or is it a 50 oz imbalance. I want to make sure before it all gets installed. What is the visible difference?
Thanks
Old Jul 7, 2005 | 05:40 AM
RTM's Avatar
RTM
The 50 oz weight is bigger but you need to know what your looking at. Auto or manual flywheel? I can't reall the actual measurement of the two but I know what it is when I look at it.
Old Jul 7, 2005 | 05:59 AM
RaleighDad66
I only have the one and it's an AOD but it is going on a 71 302 so I know I need the 28. But the question is how do I tell if it is 28 or not?
Old Jul 7, 2005 | 10:06 AM
RTM's Avatar
RTM
There will be a weight welded to the back of the flywheel and for the 50oz I think the weight is about 3 inches long and for the 28oz it's about 2 inch in length and they both should be about 1 inch wide.
Old Jul 7, 2005 | 10:56 AM
RaleighDad66
I'll measure the length of the weight and report back...
Old Jul 7, 2005 | 11:00 AM
Txquadhunter24's Avatar
Txquadhunter24
If the flexplate you have is from the same donner as the AOD is from?
If so and it came from a 302 you'll have the wrong balance for your older 302.
If it came from a 351w you'll have the older 82 back 28oz. The AOD/351w was only found in the crown vic.
You can take your flexplate to a good mechine shop near you and have it balance correctly without costing to much and to be sure it's right.
Old Jul 7, 2005 | 02:55 PM
RTM's Avatar
RTM
Now that was some good advice. I will have to remember this.
Old Jul 7, 2005 | 09:17 PM
RaleighDad66
I measured the weight and it is 4 inches long. Ouch
The flexplate is not from the same car. Pieces are from all over blue country.
Old Jul 7, 2005 | 09:29 PM
RTM's Avatar
RTM
I would say it's the 50oz balance then.
TigerDan
Nov 28, 2023 06:06 PM
Glaser67
Mar 23, 2016 09:02 AM
Glaser67
Mar 20, 2016 09:55 AM
bankog1
Oct 23, 2015 11:50 AM
Handegard
May 10, 2007 02:39 PM
