torque converter
Old Dec 21, 2004 | 12:38 AM
ford390gashog's Avatar
ford390gashog
torque converter
i need to know what is the right torque converter for a 390 with c-6 i founds this one but not sure if it is the right size it is w/C-6 Transmission; 12" Diameter; 31 Splines; 1.375" (1.61" Long) Pilot; Milled Flat Hub; 4 Stud Mount; Stall 1600-1800, Ribs Angle 45 Degrees Right, Id Code B, Bolt Circle 11.44"
Old Jul 7, 2005 | 09:29 PM
n2music's Avatar
n2music
C6 manual says 20 to 36 ft. lbs. I went for the middle at 27 ft. lbs.
