Dream Beams
Old Mar 7, 2004 | 04:50 PM
Randyb12's Avatar
Randyb12
Dream Beams
Has anyone here used the 3" drop I-beams from DJM. DJM calls them "Dream Beams".
I am considering them, I have a 76 F150 2wd. I am droping the rear 5" and want to drop the front also. The 3" dropped I-beams seem to be the only way to do this. If anyone knows of a a-arm conversion please let me know.
Thanks.
Old Mar 7, 2004 | 07:54 PM
IAM.CA's Avatar
IAM.CA
I have dream beams on my ranger. I know they're not the same, but they are plenty beefy, I'd definitely reccomend them.
Old Mar 7, 2004 | 08:02 PM
Randyb12's Avatar
Randyb12
Thanks for your opinion. I am glad to hear that.
Old Mar 8, 2004 | 09:26 AM
beartracks's Avatar
beartracks
I've heard you cannot bend them to adjust the camber.
Old Mar 8, 2004 | 09:39 AM
Randyb12's Avatar
Randyb12
Your not supposed too. You can't bend the stock ones either.
Old Mar 8, 2004 | 10:20 AM
Fryzil's Avatar
Fryzil
Umm, you can bend the sock ones. Its done all the time.
Fry
Old Mar 8, 2004 | 12:51 PM
Randyb12's Avatar
Randyb12
Didn't know that. Showing my igknrence of I-beam suspension. I guess I learned enough to stick my foot in my mouth.
Old Mar 8, 2004 | 03:27 PM
Fryzil's Avatar
Fryzil
My beams were bent when I lifted my truck and a buddy of mine had his bent when he lowered his but you can only go a couple inches lower with stock beams, otherwise you run into frame to beam clearance issues. Good luck on lowering it, they look real nice when you drop them.
Fry
Old Mar 9, 2004 | 10:17 AM
daddzwaterboy's Avatar
daddzwaterboy
also look for the beams at AIM or truckin.com I hear those are good too. You can also buy a 4" lowered coil from Blue Oval Truck Parts. I will be trying to cut my coils and then install a flip kit in the rear with a c notch...
Good luck and let us know how it goes.
Old Mar 9, 2004 | 08:09 PM
Randyb12's Avatar
Randyb12
If you have headers and use shorter coils watch out for tie rod to header interference. I tore a hole in my drivers side header. I had to get stock height springs and a new header. That is why I am looking at the dream beams.
Old May 4, 2004 | 09:37 AM
79f150TX's Avatar
79f150TX
If you want to go to A-arms Fat Man Fabrications sells a Mustang II style crossmember for our trucks. It's not Mustang II stuff it's mustang II STYLE. It's built heavier for trucks, Fat Mans makes some really good stuff. You can go really low with this set up, air ride even if you want. It's not the easiest way but if you want really low or A-arms it's probably your best bet.
Nick
Old May 26, 2004 | 09:54 PM
nrselu's Avatar
nrselu
Question Lower F 150 2wd
I am told you can lower a 2wd F 150 2" without changing the I beams?
It was said that you can cut 2" out of the original front springs to lower it 2".
To get the truck to sit level I have seen the rear axle moved above the leaf springs which lowered the rear 3".
Has anyone else done this?
How was the camber corrected?
Old May 27, 2004 | 11:06 PM
Randyb12's Avatar
Randyb12
Thanks for the link to fatman's. Cool stuff.
csm_274
Apr 8, 2016 04:06 PM
f100today
Apr 2, 2016 08:09 PM
GM4WALLS
Oct 6, 2013 01:34 AM
Oldred67
Dec 18, 2012 03:43 PM
marioc956
Offroad & 4x4
13
Mar 21, 2008 04:39 PM
