Sponsored by: Kumho
ABS light
Old Jul 5, 2005 | 01:38 PM
rett8799's Avatar
rett8799
ABS light
have a 99 f150 v6. Recently I have had an ABS light with clicking noise when applying brakes, seems to be getting worse, especially when it rains.
Any idea on what it is?
Old Jul 6, 2005 | 02:53 PM
jtmerritt's Avatar
jtmerritt
Are you sure the clicking noise isn't the ABS pump? I had this problem on a 90 Continental and it turned out to be a bad wheel sensor. You are going to have to get any error code(s) scanned from the ABS system to determine the problem. Used to be you could use the pre OBDII scanners to scan codes from the ABS system but on a 99 probably requires an OBDII or specialized scanner. You might try and go aound to each wheel and check the connection at the wheel sensor and do the same at the ABS module, pump, etc. Especially since it seems to be affected by when it rains.
John
Old Jul 6, 2005 | 05:06 PM
rett8799's Avatar
rett8799
Well it happened again today! It sounds like the clicking sound is coming from under the hood, in front of the drivers side dash! When it clicks the brake pedal pulsates!
Beastlyforddude
Feb 16, 2011 01:54 PM
mikevv
May 10, 2009 01:01 PM
hdbiker04
1997 - 2003 F150
Nov 19, 2006 11:00 AM
jayhawkfan
1983 - 2012 Ranger & B-Series
Feb 19, 2004 03:29 PM
