Front coil springs
Old Jan 5, 2003 | 11:07 PM
rfgree's Avatar
rfgree
Front coil springs
On my '78 F-100 the previous owner replaced the
original front coil springs with a set of 4x4 coil
springs. They make the front of the truck set to high so
I would like to put a set of the
original ones back on. I was told there was some
kind of clip
that you could attach to the springs that
would take sone of the
height off the set I have on now rather then putting on
new coil springs. Also if that doesn't work how can I tell
if a used set of springs are worn out? Thanks ..
Bob
Old Jan 5, 2003 | 11:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Front coil springs
Don't mess with clips and spacers. You can get a new set of springs at an auto supply store or there are junkyards, but you can never tell the condition of the springs. When you lift up the front with a set of springs it wipes out the caster and camber settings for your front end.
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum]
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old Jan 8, 2003 | 08:36 AM
strider9's Avatar
strider9
Front coil springs
I had a mechanic tell me that the best way to clear up the front end alignment (apart from new king pins and axle pivot bushings) was to replace the coil springs, especially if they are high mileage. My local auto parts store priced them at $80 for the pair. I would stay away from the junkyard for springs, as you don't know how much they will sag. Good luck !:-)
Old Jan 8, 2003 | 02:34 PM
mudmnky's Avatar
mudmnky
Front coil springs
One of the guys here just put a new set of Eaton springs on his truck. I belive it was laptopgeek(?). Maybe he will chime in... They were not very expensive, and a great alternitive to stock.
Old Jan 8, 2003 | 03:10 PM
dfisher1's Avatar
dfisher1
Front coil springs
All,
There is nothing wrong with stock coil springs. There are a half dozen to chose from for any given year.
You will have to get it aligned after replacement.
Go to the store, spend your $80, bolt them on, get it aligned, and be done with it.
KingFisher
Old Jan 8, 2003 | 05:15 PM
kaotikedge_111100's Avatar
kaotikedge_111100
Front coil springs
Check out my gallery, I just installed new springs in my truck, but to raise instead of lower, but I think that it pretty much restored the ride height to factory, I paid $85 for new coils.
Old Jan 8, 2003 | 05:39 PM
fordguy76's Avatar
fordguy76
Front coil springs
Redmanbob
Jun 20, 2014 02:05 PM
NW 150
13
Sep 17, 2013 02:07 PM
Mountianeer
Offroad & 4x4
31
Aug 5, 2008 06:16 PM
mjlevi
Nov 14, 2006 03:48 PM
aerocolorado
Aerostar
13
Nov 13, 2006 03:26 PM
