Sponsored by: Kumho
Front Coil Spring question
Old Nov 13, 2006 | 08:25 PM
mjlevi's Avatar
mjlevi
My truck is an 05 F250 PSD, I have the factory 6000 pound coil springs on my vehicle, from what I understand the snow plow package set-up is with the 6600 pound coil springs, If I were to install the heavier spring set on my truck, would it require a re-alignment of the front end? and/or if I'm wrong about the numbers, please correct me.... thanks!
Old Nov 14, 2006 | 03:48 PM
385seriesHemi's Avatar
385seriesHemi
Well the springs that have the 6600lb or whatever Ford's plow spring rating is (I dont know) will probably change the alignment because they might be little taller along with being a stiffer coil. But as for doing and suspension work in general it is a must for re-alignment especially when putting a differant spring in so your tie rods and tires do not wear out prematurely.
radium
6.7L Power Stroke Diesel
18
May 14, 2016 06:47 AM
resonateur
Oct 26, 2015 10:01 PM
paulmac
Sep 17, 2015 08:54 PM
toothser
Aug 27, 2015 01:33 AM
DernMooseAk
Modular V10 (6.8l)
Apr 21, 2009 12:44 PM
