Offroad & 4x4
driveshaft angle
Old Jul 4, 2005 | 11:31 PM
fordinmudd's Avatar
fordinmudd
driveshaft angle
since i put my dana 60 front axle on my truck (the truck is a 95 250 4x4 auto) my front driveshaft is sitting at a strange angle.whats the best wat to fix this?it seems like its sitting to high.can i use a front drive shaft out of another truck to fix this?maybe from a 350?
Old Jul 4, 2005 | 11:34 PM
RubberDuck's Avatar
RubberDuck
What do you mean by too high?
RubberDuck
Old Jul 5, 2005 | 08:08 AM
mark a.'s Avatar
mark a.
I would check caster first.
Old Jul 5, 2005 | 08:10 AM
Amtek's Avatar
Amtek
could you possibly take a picture of it? If you mean the pinion of the axle is pointed upwards, causing the driveshaft to be closer to the engine? If the pinion is pointed too high up your steering wheel wont want to center itself after making a turn, and the pinion bearings wont get enough lubrication. Is the truck lifted? if so, how much?
A new driveshaft wont fix the angles.
I drew this up in MSpaint...tell us which one your axle looks like and we can tell you how to correct it:
Old Jul 5, 2005 | 10:03 AM
fordinmudd's Avatar
fordinmudd
its like the center one and yes the truck is lifted 9 " of lift and my steering wheel is always off to the side when I drive down the road and I had an alignment.i know there must be a way to fix it.ill try to get a pic of it later today.later
Old Jul 5, 2005 | 04:01 PM
proeliator's Avatar
proeliator
Your pinion is pointing down!? (nice drawing btw amtek). Since you mentioned you swapped this in, if the pinion points down like that after bolting up you need to rotate your perches and get your u-joints in phase.
Old Jul 5, 2005 | 06:29 PM
Amtek's Avatar
Amtek
What about adding a steel shim to the leaf pack? With the center bolt running through it, It should still be safe. I had to do this to mine after bolting the sky jacker 4 inch lift leaf springs. It left the pinion pointing downwards so I clamped the leaf springs together, took the center bolt out and slipped in a 4 degree shim with the thick side towards the front. This brought the pinion angle to zero.
Old Jul 5, 2005 | 07:23 PM
proeliator's Avatar
proeliator
You can certainly use a shim if its not off that much. He kind of made it sound majorly bad...which is when a shim becomes a non-possibility and your stuck rotating your perches. But shims are worth mentioning since we really don't know HOW many degrees off his is.
Old Jul 5, 2005 | 09:54 PM
mark a.'s Avatar
mark a.
Without any precise caster angle being known, it's impossible to know how much you can shim the axle for pinion angle. Keeping in mind that pinion angle is relitive to caster (unless you turn the C's), meaning you only have so much pinion angle to spare before you run out of acceptable caster degrees. It's a compromise. Either way you can only shim maby 8 deg. before you put the u bolts into too much of a bind & with a front Dana the drivers side perch can not be moved, it's part of the pumpkin. Hope this helps.
Old Jul 5, 2005 | 10:52 PM
proeliator's Avatar
proeliator
Its really hard to know without the actual angle. I'm glad Mark spoke up though....I actually meant rotate the "c"s not the perches....if the angle's so bad as to actually need it. Brain thinks one thing fingers type another. I do know one thing for sure...dynamite would fix it
