Coolant
Old Jun 10, 1999 | 02:49 PM
RogerW's Avatar
RogerW
Coolant
I seem to be using more coolant than I think I should. I have a new water pump and I don't see any leaks, but I am filling up my overflow at least weekly. Is this normal for an 87 F150, 302?
Old Jun 10, 1999 | 06:19 PM
Straightsix's Avatar
Straightsix
Coolant
If you haven't already done so, check your oil. If you blew a head gasket or cracked the block, the coolant could be leaking into the oil...if it is, the oil will look like...well...oil with coolant in it. It is very obvious.
Old Jun 11, 1999 | 03:55 PM
RogerW's Avatar
RogerW
Coolant
No, I just changed the oil last night, it looked normal except for a little overused. Also, I check the overflow last night and the water i put in a few days ago is still there, so we will see.
Old Jun 12, 1999 | 10:15 AM
David DeLeon
Guest
Posts: n/a
Coolant
You probaly have a bad radiator cap, what is happening is the presure is building in the radiator, normal, but the cap allows the presure to release too early, this causes the overflow to overfill, then when it cools it draws what little is left in the overflow, back to the radiator. Replace your bad cap with a new one.
Dave
Old Jun 13, 1999 | 07:28 PM
car36's Avatar
car36
Coolant
I had the same problem on my F250. Mine was a defective radiator cap. I wouldn't go throwing a bunch of parts at it, though, without pressure testing it. If you don't have a pressure tester, and don't want to buy one, pay a local shop to do it. It's not expensive and will pinpoint the leak. One of the best tools I've ever bought was a pressure tester. They're not expensive and usually have adapeters that will allow you to test your cap, too.
Make sure your cap's gasket is good and see if there's any dirt on between the gasket and where the gasket hits the radiator. Check the overflow tank's hose for holes.
Vehicles with overflow tanks (anthing made in the last 30 years) DON'T "use" coolant. You shouldn'tbe loosing ANY! Small leaks are a bitch to find.. have it tested.
Old Jun 14, 1999 | 08:26 AM
RogerW's Avatar
RogerW
Coolant
Thanks for all the good info, I will replace the Cap tonight...
Old Jun 14, 1999 | 01:29 PM
RogerW's Avatar
RogerW
Coolant
Finally found my leak, it is coming from the thermostate area, gonna put on a new gasket and install a new thermostate tonight...
Old Jun 15, 1999 | 08:21 AM
RogerW's Avatar
RogerW
Coolant
Replaced the thermostat last night and that solved my coolant leak. The gasket was pretty bad off. Thanks for the help.
Old Jun 15, 1999 | 09:02 AM
slikness's Avatar
slikness
Coolant
jethrodean
6.7L Power Stroke Diesel
Mar 2, 2017 11:20 PM
sgeorge
Oct 27, 2016 09:59 AM
akblackfoot
Apr 6, 2016 05:26 PM
ka2rkv
Dec 18, 2015 08:18 AM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
