"Spinning" ball joint
I'm doing a ball joint job on my 92 F150 4WD. The lower ball joint nut is really a bugger. Finally got it to turn after a few applications of PB Blaster and a cheater bar. But, now, it appears that the whole ball joint is turning, instead of just the nut.
Any ideas/suggestions on what I can do now? Thanks, guys, in advance.
You've got to find a way to put pressure on the joint. I used a fork splitter, like the ones used on tie rods, and a bottle jack. I bought some crappy autozone ball joints for my F-250 beater and 1000 miles after installing them I realised the bottom was one was loose. I had the same situation. It's one of those things you've just got to work at and find what works. In the end, you've just got to find a way to put pressure on it.
OK, so if I'm reading you right, maybe I should use a bottle jack and the weight of the truck to try and hold it. Then, if it still spins when I try to loosen the nut, I should drive a pickle fork in between the joint and the knuckle. Right?
Thanks for the reply.
Thanks, guys, for the suggestions. I should have made clear that I'm trying to get the old ball joint loose, as opposed to installing the new one.
Anyway, maybe using the bottle jack will be the trick.
Quicklook2, where did you hold the joint with the Channel Locks? Is there enough below the knuckle to get them on it? Or, were you assuming there was enough of the stud exposed below the nut to grip?
Thanks, again, everyone.
as everyone is trying to describe, you need to hold the pieces together. i did not do a f150, but many others. the ball is loose, the nut turns the ball not letting you remove nut, you need to put pressure so the ball does not turn, eithe r wedgeing something like a pickle fork or holding the pieces together tightly with large channel locks, not the small one, the big mothers sears sells.
colin1966
15
Oct 23, 2016 08:36 PM
crandallf150
Aug 20, 2016 05:30 PM
banjopicker66
24
Apr 8, 2013 11:49 AM
