Ball joints?
Old Sep 10, 2012 | 12:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Ball joints?
Are the ball joints replaceable on an 04 navigator, or do I have to buy the $100+ a-arms with the joints in them?
Old Sep 10, 2012 | 12:46 PM
alloro's Avatar
alloro
You'd have a definitive answer by checking to see if your local auto parts store sells just a ball joint without the control arm.
Old Sep 10, 2012 | 01:17 PM
Moto Mel's Avatar
Moto Mel
I have not had to do mine, yet. I'm pretty sure the uppers will require buying the A-arms and the lowers are just the ball joints. If it's like the Mark VIII the A-arms will include the bushings as they usually go out at about the same time.
Old Sep 10, 2012 | 02:02 PM
cookie88's Avatar
cookie88
FTE Emeritus
Therein lies the problem. They show both but carry neither. The picture of the ball joint doesn't look "normal" and if they are mounted in aluminum arms...... Is there a way to get them pressed out without hogging them out so the new ones won't fit?
Old Sep 10, 2012 | 03:20 PM
alloro's Avatar
alloro
From what I can find out, only the lowers are separate from the arm. While the uppers are a permanent part of the upper A-Arm. Your parts store might be listing just the ball joint, but I'll bet it's a number for the lower ball joint.
Old Sep 10, 2012 | 04:26 PM
Moto Mel's Avatar
Moto Mel
My local AutoZone has the ball joint as just the part for my truck and for very little more they have the A arm with the bushings and the ball joint
You would be better off to get the A arm assembly as it has the bushings and ball joint, otherwize you will do more work trying to change just the ball joint.
I have found that AutoZone and Advance carry the same parts at about the same price. Do what's best for you.
Here's a link; AutoZone | Auto Parts & Accessories | Repair Guides & More
Duralast/Ball Joint - Upper
For your 2000 Lincoln Truck Navigator 4WD 5.4L SFI DOHC 8cyl
Price:$31.99
Part Number: FA2242
Alternate Part Number: K80014
AVAILABILITY:
STORE PICK UP
AVAILABLE
Normally stocked at your local store.
SHIP TO HOME
AVAILABLE
Ships within 2 business days.
ADD TO CART
Eligible for FREE 2-Day Shipping
learn more | sign in
Part Number:
FA2242
Weight:
1.6 lbs
Warranty:
Limited Lifetime
Notes:
Press in type. 1 7/8" diameter. All-replacement ball joint for most aftermarket control arms; press-in diameter 48.25mm/1.900".
Shipping Information:
Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Product Service Bulletin:
Instructional DVD Available
Old Sep 11, 2012 | 11:52 AM
cookie88's Avatar
cookie88
FTE Emeritus
That is exactly right. Lowers are $32 each and the uppers are $104 for the a arm
Old Sep 11, 2012 | 12:01 PM
Moto Mel's Avatar
Moto Mel
Something or someone is not right, here's what I've found;
Duralast/Control Arm - Upper
<!-- Invodo video service response was null -->
Part Number: FA4067
Warranty: Limited Lifetime
Price:$38.99
<FORM id=formId0 class=formContainer method=post name=formIdName0 action=/autozone/parts/Duralast-Control-Arm-Upper/2000-Lincoln-Navigator-4WD/_/N-jeiomZ8oz71?itemIdentifier=334819_0_5913_&_DARGS=/autozone/catalog/parts/partsShelf/singleshelf.jsp autocomplete="off"><INPUT name=_dyncharset value=ISO-8859-1 type=hidden>
<INPUT name=_dynSessConf value=-1191509161235267798 type=hidden>
<INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.errorURL value=/autozone/parts/2000-Lincoln-Navigator-4WD/Control-Arm-Upper/_/N-jeiomZ8oz71 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.errorURL value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.catalogRefId value=334819 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.catalogRefId value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.productId value=2285-0 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.productId value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.categoryId value=46-0 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.categoryId value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.productType value=00 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.productType value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.itemIdentifier value=334819_0_5913_ type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.itemIdentifier value=" " type=hidden><INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.catalogVehicleId value=2590102 type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.catalogVehicleId value=" " type=hidden><INPUT name=shopRunnerEligible value=true type=hidden><INPUT id=storeAvaRadioBtn334819 name=/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore value=true type=radio><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore value=" " type=hidden>
<LABEL for=storeAvaRadioBtn334819>STORE PICK UP</LABEL>
AVAILABLE
<INPUT id=onlineAvaRadioBtn_334819 name=/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore value=false type=radio><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.sendToStore value=" " type=hidden>
<LABEL for=onlineAvaRadioBtn_334819>SHIP TO HOME</LABEL>
AVAILABLE
<INPUT name=/atg/commerce/order/purchase/CartModifierFormHandler.addItemToOrder type=hidden><INPUT name=_D:/atg/commerce/order/purchase/CartModifierFormHandler.addItemToOrder value=" " type=hidden>ADD TO CART
</FORM>
Old Sep 12, 2012 | 06:24 AM
broncoholic's Avatar
broncoholic
You are not right. You are looking at parts for a 2000. The op has a 2004.
Old Sep 12, 2012 | 08:58 AM
Moto Mel's Avatar
Moto Mel
You are right, the spec.s clearly say the parts fot a 2000 Navigator. I was only showing him that the parts are likely available either way from Autozone or similar stores.
Old Sep 15, 2012 | 11:57 AM
cookie88's Avatar
cookie88
FTE Emeritus
Yeah.... That's what I bought. Upper A-arms with ball joints installed in them. $103.99 each.
Got bigger fish to fry though. I have it in the air now and I can't find anything wrong with any of the ball joints, but the big bolts that hold the lower control arms to the sub frame are sliding around in the hole like they're loose, but they aren't loose. I think whatever *** clown did the alignment for mom messed something up then claimed ball joints to cover his tracks.
Not a happy camper right now. Not only do I have $300 worth of parts I don't need but now I have to remove the entire front suspension to get at the real problem........ Not to mention the two brand new Pirelli Scorpions up front are trashed.
Old Sep 15, 2012 | 01:14 PM
NemesisNJ's Avatar
NemesisNJ
Sounds like lower control arm bushings. I just ordered all this for my Expy, from Rockauto, all Moog for just under $300 shipped, upper arms w/ joints greaseable, lower ball joints greasable and bushings, camber bolts, and I honestly forget the rest. Bushings for both sides, 2 pairs should be around $48 each or so depending on where you shop.
Club Wagon
1997 - 2003 F150
21
May 3, 2013 10:03 PM
jayc3169
Feb 18, 2012 05:47 PM
shinew
Mar 7, 2004 10:06 AM
ObiWanJak
May 19, 2003 02:01 PM
