Windshield Washer
Old Jun 27, 2005 | 03:29 PM
hdwideglide94's Avatar
hdwideglide94
Windshield Washer
I thought I could diagnose this problem, but I am not coming up with the answer. On my wife's 2000 explorer, when you try to use the lever to wash the windshield, the wipers come on for about 4 sweeps like they should, but the pump doesn't come on. I unplugged the connector to the pump, connected a volt meter using a known ground, and no power is going there with the washer switch engaged. Is it the multi function switch on the steering column, or something else? Seems to me if it was the switch on the column, the wipers wouldn't work either.
Also, I read that on 97 multi function switches, you can clean them, but the 2000 model appears to not have the plastic "cap" you can take off to clean the connections.
Tks for any help!
Old Jun 27, 2005 | 05:04 PM
87 XLT's Avatar
87 XLT
Dont know if yours is wired the same, but on a 97 theres a seperate relay that controls the washer pump motor. Might want to check for that.
Old Jun 27, 2005 | 05:51 PM
JerrySimm's Avatar
JerrySimm
Did you check your fuses?
Old Jun 27, 2005 | 10:32 PM
hdwideglide94
Good point Jerry. Reality check for me...I should know to start with the simplest things and work from there. I'll check the fuse out tomorrow. Hopefully that is it.
Old Jun 28, 2005 | 09:26 AM
FloatJ's Avatar
FloatJ
I agree to check the fuses first, but this problem is indicative of a bad MFS. This happened to me ('95 XLT) for a long time. It was a nuisance but I could usually get the washer to work on the second or third time. Eventually the switch failed further and I had no headlights. Replacing the switch was quick, easy, and it solved my windshield washer problem.
Old Jul 6, 2005 | 11:56 PM
hdwideglide94
Well, I checked the fuse and it was bad. I replaced it, but still no washer. The wipers work when I try to use the washer, but still no water. The lines are clear, the resevoir is full, etc. I'm trying to narrow this thing down to keep from wasting money on parts I don't need. I tested for voltage at the pump and there is none.....where is the relay and how can I test it? Also, the rear washer doesn't work (I believe the rear uses the same pump and resevoir, right?)
Old Jul 7, 2005 | 07:43 AM
FloatJ's Avatar
FloatJ
At least on my '95 the rear has its own reservoir in the compartment with the jack. One would presume that it would require its own pump too. Is your rear reservoir empty? There should be a place to fill it on the left rear "door jam" if you open the rear lift gate.
Old Jul 7, 2005 | 11:48 AM
bulldog3531's Avatar
bulldog3531
On my 98 and 04 explorer the rear wiper uses the same reservior as the front. I am not quite sure about the pump.
Old Jul 11, 2005 | 03:09 PM
hdwideglide94
2000 Explorer: Windshield washer relay location and how can I test it???? I've read it's in the fuse box in the engine compartment, but how can I identify it? Please help before the wife starts driving my 98 F150 4x4 :-O
Old Jul 11, 2005 | 10:36 PM
texan2004's Avatar
texan2004
I thought that there was a schematic of the relay box in the owner's manual in my 96. I would think it would be in the 2000 as well.
Old Jul 11, 2005 | 11:42 PM
JSchilberg's Avatar
JSchilberg
Try going here for the "Glove Box Manual" (owners operation manual):
http://www.genuineflmservice.com/default.asp?page=E4
It may contain the relay information you're trying to find.
JS
budman325
Mar 23, 2023 11:00 AM
pdd
21
Apr 3, 2008 06:23 AM
FLOW_BOY
1978 - 1996 Big Bronco
Jan 21, 2005 01:13 PM
tommowry
Dec 18, 2003 04:06 PM
