Sponsored by: Real Truck
windshield wiper motor
Old Dec 9, 2011 | 02:03 PM
budman325's Avatar
budman325
have a 2002 f250, wipers and washer pump wont work, replaced multi function switch and nothing, when turning on you can hear a slight clicking sound coming from wiper motor area, and to top it off I don't have the manual to see what fuses and relays are for what!!!! thanks for any input
Old Dec 9, 2011 | 05:22 PM
dchamberlain's Avatar
dchamberlain
You should be able to download the Owner's Manual here.
https://owner.ford.com/servlet/Conte...ionalEventPage
The wiper motor gets power from fuse 33 and 106.
Old Dec 9, 2011 | 07:00 PM
Kajtek1's Avatar
Kajtek1
This is one of those 30 amp fuses. My motor got shorten couple years ago and made pretty big smoke on parked car before the fuse burned out.
Old May 17, 2020 | 04:35 PM
Dsimes's Avatar
Dsimes
Are both of these fuses under the hood? I know the 30 amp fuse is under the hood... not sure if it is the 33 or the 106.
Old Mar 23, 2023 | 07:24 AM
MYTRUCKNOWRATTLES's Avatar
MYTRUCKNOWRATTLES
maybe this video will help. I don’t know what vehicle year you’re talking about.
Old Mar 23, 2023 | 11:00 AM
S-squatch's Avatar
S-squatch
It has relays for both, ground side switch from the gem. The clicking is likely the relay.
not sure on a 02 the numbers or locations. Once you find them you can test at the relay for missing powers.
On earlier models the grounds for the motor and pump are in different locations.
Guessing it is the 30a fuse, or wiring.
apache12
Oct 15, 2020 01:51 PM
Whisk3y
2004 - 2008 F150
Jun 8, 2016 03:32 PM
Icefan71
Feb 8, 2013 01:58 PM
Derrick lane
Nov 22, 2010 05:25 PM
greenterror
Jan 2, 2009 05:35 PM
