Sponsored by: Real Truck
Computer Error Codes Extraction Method
Old Jun 26, 2005 | 11:45 PM
palindromelol's Avatar
palindromelol
Computer Error Codes F250 2002 Lariat SC 4X4 5.4L
Is it possible to extract any error codes from the Truck's computer using a sequence from the cab? I have a laptop computer interface with the OBDII but I don't always have it in the truck. My neon expresses its codes by turning the key on/off/on/off/on and waiting. Is such a method available with the F250's?
Old Jun 27, 2005 | 12:02 AM
Greg250's Avatar
Greg250
Press the trip odometer reset and turn the key on to ignition. Keep pressing the reset button to go through all the tests. This gives you all sorts of info on the digital display. Error codes start with DTC.
Old Jun 27, 2005 | 01:18 AM
palindromelol
NO WAY!!! That is shweeeet!! I'll use that one later today. Where did you find that little nugget? BTW... what are you doing up so late... I'm only up because of reflux. (BURP)
Old Jun 28, 2005 | 09:07 AM
CmprSpecial's Avatar
CmprSpecial
Check here for some more information https://www.ford-trucks.com/forums/s...=trip+odometer
Old Jun 28, 2005 | 10:32 AM
Kep4's Avatar
Kep4
Jäger
Thanks CamperSpecial!
Now I'll have something to do at my wifes family reunion this weekend.
Old Jun 28, 2005 | 10:37 AM
palindromelol
I was scouring the internet trying to find the DTC codes. I hooked up my OBDII and got no codes. I tried the trip miler/ignition key trick and got P9362 and D262. The link CmprSpecial cited above is helpful, albeit incomplete.
I haven't poped for the Helm Inc Manual yet. I will likely do so.
Old Jun 28, 2005 | 06:03 PM
sriddle's Avatar
sriddle
Does this work on the '05?
I just checked and it does. You just have to push reset and select at the same time. (they are two buttons on the 05) You also have to let go of it as soon as test shows up as it only gives you a second or so.
raptor2005
Feb 15, 2010 03:03 PM
roller_steve
Aug 2, 2008 11:35 PM
jetedwards
Jul 2, 2008 09:41 PM
290
Nov 15, 2006 04:00 PM
garyb
1997 - 2003 F150
Sep 19, 2000 08:37 AM
