diagnostic trouble code
Old Jun 26, 2005 | 01:09 PM
20012001's Avatar
20012001
Unhappy diagnostic trouble code
My check enginge light has been on for a while now. I went to DEQ in order to register my truck and I failed. I got a code of PO171, system too lean (bank 1).
Does any one know what part I will need to fix this problem?
20012001
Old Jun 26, 2005 | 01:37 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 26, 2005 | 04:38 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
What engine do you have???
Old Jun 27, 2005 | 10:01 AM
20012001's Avatar
20012001
I have the 3.2
Old Jun 27, 2005 | 08:01 PM
Ken00's Avatar
Ken00
I think you mean 3.0. I would start by looking for vacuum leaks, I'm sure the other users will have some more suggestions.
Old Jun 27, 2005 | 09:46 PM
Rockledge's Avatar
Rockledge
Bank 1 is the passenger side of the engine. The PO171 code means that too much air is being burned in the combustion chamger(s) on that side, and hence the oxygen sensor on that side is sensing a "lean" condition. That's why Ken00 is suggesting that you look for vacuum leaks, such as failing vacuum hoses & connections, because that's where excess air can be drawn into the engine. Another example is a bad upper intake manifold gasket that can also allow air into a particular cylinder or two. So it's things like that you should be thinking about.
Good luck with the code and the test.
Old Jun 28, 2005 | 01:47 AM
pete dumbleton's Avatar
pete dumbleton
Rockledge, is there any reference place to look up the likely causes of the various codes, like you just did? You went from the code to the likely cause -- Some are less obvious than others...
Old Jun 28, 2005 | 05:49 AM
Rockledge's Avatar
Rockledge
Ford OBD-II DTCs
Old Jun 29, 2005 | 03:18 PM
pete dumbleton
Beautiful!! Thanks very much!!! Just what I was looking for <big grin>
Pete
steedpower
Oct 6, 2016 08:30 AM
Sledhead3
20
Sep 20, 2016 01:09 PM
jfon101231
Feb 20, 2016 09:19 AM
92will
Jul 28, 2011 08:28 PM
Joetool
3.8 & 4.2L V6
Nov 27, 2005 08:33 AM
