Code 1537 on 1997 E250 4.2, help please.
Old Nov 15, 2005 | 03:35 PM
Joetool's Avatar
Joetool
Question Code 1537 on 1997 E250 4.2, help please.
Autozone came up with a code 1537 today on my E250 4.2 1997. He said it was not a code they could "read" and tell what the problem was. The code reader did show something about Throtle control, or speed control but I didn't get a good look at the decoder. Any info on this code?
Thanks,
Joe
Old Nov 15, 2005 | 09:17 PM
ratstang's Avatar
ratstang
I believe your Intake Manifold Runner Control is stuck open. You might check for vacuum leaks. Or, you might need to replace your IMRC vacuum pump.
Old Nov 16, 2005 | 07:06 AM
BrianA's Avatar
BrianA
I agree. I am not positive but believe 1537 is an IMRC problem. Not sure if it means stuck open or stuck closed, but that is where I'd go looking.
Old Nov 16, 2005 | 12:35 PM
Joetool's Avatar
Joetool
Thanks, I'll take a look.
Old Nov 20, 2005 | 06:25 AM
bokker's Avatar
bokker
if imrc is stuck open the symtems are, loss of tick-over and lack of performance in the lower rev range. in my case vacuum leak was the cause.
Old Nov 26, 2005 | 12:54 PM
Joetool's Avatar
Joetool
I have some time to finally work on this problem. I'm not familiar with the IMRC, so, where is it located, whats it look like?
Thanks,
Joe
Old Nov 26, 2005 | 02:40 PM
bokker's Avatar
bokker
the imrc vacuum units are to be found at the back of the engine they are black and have black vacuum pipes running to them. they inturn open the the rails that move the flaps on the dual intake.
in my case the flaps were open all the time.
the best way to check that the flaps are free to move is to suck on the pipe that goes to both of them and listen carefully, you will hear them open and slap shut when the vacuum is released.
it is a long reach to suck on the pipe but it will tell you if all is ok.
wd40 can be used to free off any sticking rails as the flaps need to be shut, up to about 2,700 revs, then open with vacuum, to go to full throttle. (just like a twin choke carb).
hope this helps bokker.
Old Nov 27, 2005 | 08:33 AM
Joetool's Avatar
Joetool
Thanks Bokker, that will get me started.
Joe
kdrifter440
1997 - 2003 F150
Jun 22, 2008 07:27 PM
JKVAJL
1997 - 2003 F150
Feb 5, 2005 08:20 AM
snikwahttam
1997 - 2003 F150
Dec 23, 2003 04:30 PM
mgb150
1997 - 2003 F150
Oct 27, 2003 08:22 AM
chocolate moose
1997 - 2003 F150
Dec 10, 2002 04:05 PM
