Windshield WASHER not working?
UPDATE: the connector is a oval rubber style connector with 2 pins (+12V and ground I presume). I cleaned the pins on the motor with some fine sandpaper
and did the same to the rubber female recaptacles in the plug. added a bit of dialectric grease....put back together and working great again.
2026!
Same thing here. Power probe gets the motor turning and spraying so it is in the switch or connection.
Unfortunately I am without a helper to push the sprayer button for me to check voltage!
Edit: Was able to reach it just barely. Power to the pig tail when the button is pushed.
Squished the female connector a bit, added some new dialectic grease, plugged it in and Bob's your uncle. All is good.
2026!
Dave ----
mikeyswood
Sep 20, 2005 10:17 PM
