Windshield WASHER not working?
UPDATE: the connector is a oval rubber style connector with 2 pins (+12V and ground I presume). I cleaned the pins on the motor with some fine sandpaper
and did the same to the rubber female recaptacles in the plug. added a bit of dialectric grease....put back together and working great again.
Same thing here. Power probe gets the motor turning and spraying so it is in the switch or connection.
Unfortunately I am without a helper to push the sprayer button for me to check voltage!
Edit: Was able to reach it just barely. Power to the pig tail when the button is pushed.
Squished the female connector a bit, added some new dialectic grease, plugged it in and Bob's your uncle. All is good.
Dave ----
