windshield wiper fluid
Old Sep 16, 2010 | 01:41 PM
cleaningbug94's Avatar
cleaningbug94
Hello i have a 1998 ford expedition 4x4 and i need to get the windsheild wipers fixed heres my problem I hold down the button for the front windsheild wipers they dont turn on. I turn the spray on in the back and it sprays windshield wiper fluid so is my switch bad because the motors are good in the front.
Old Sep 16, 2010 | 02:53 PM
alloro's Avatar
alloro
Yes it's the multi-function switch. You can usually confirm this by turning on the right or left turn signal, then push the switch. 9 out of 10 times if the problem is a worn switch, doing this will make the washer fluid squirt.
Old Sep 16, 2010 | 06:13 PM
cleaningbug94
How much should a new one cost my father just passed away unexpectedly and will be crossing the country so its kind of a nesscesity
Old Sep 16, 2010 | 06:40 PM
alloro's Avatar
alloro
About $60 online and $75 at your local auto parts store.
Old Sep 25, 2010 | 01:58 AM
riccoh's Avatar
riccoh
before you spend any money, pull the cover for the stering wheel and see of any of the wires have come a bit loose on the multi function swtich, I had the same problem and bought a new one and when I was replacing it ... I saw the wires pulled out a bit, pushed them back in and they worked just fine... just a tought
Old Sep 25, 2010 | 09:17 AM
madsonp's Avatar
madsonp
Sorry to hear about your father.
Old Sep 25, 2010 | 09:28 AM
2000-EB-EXPY-AWD's Avatar
2000-EB-EXPY-AWD
Id have to agree with both above. The switch is probably bad, but it wouldn't hurt to check connections first.
Old Sep 25, 2010 | 12:58 PM
minitrk's Avatar
minitrk
Sorry to hear about your dad.
Before you spend any money you should check THIS FIX out.
Old Sep 27, 2010 | 06:15 AM
Gevans17's Avatar
Gevans17
Multi-function switch
mine has been changed twice already.
Old Sep 27, 2010 | 08:50 AM
alloro's Avatar
alloro
Depending on where you drive makes a difference on how long the switch lasts. If you do mostly town or city driving there are more turns, so the switch operates often. If you drive mostly out in rural or suburbs where the roads are longer with less turns, then the switch lasts longer.
Old Sep 27, 2010 | 10:19 PM
Gevans17's Avatar
Gevans17
Expy multi non-function switch
It was changed TWICE while still under the original 3 yr / 36,000 mile warranty. The turn signals never died, but the wiper/washer function crapped out both times.I believe there is a post on this site detailing how to disassemble and clean this switch.
Old Sep 28, 2010 | 01:50 PM
minitrk's Avatar
minitrk
There is see my above post.
Old Sep 29, 2010 | 03:25 PM
cleaningbug94
yeah i am going to try that but i have to wait a few weeks its just so hot in phoenix
Old Oct 18, 2010 | 03:13 AM
cleaningbug94
tryed cleaning it didnt work ordered one on ebay and the shipper delievered it to the wrong house hope i get it before i move.
Volkelrunner74
Sep 23, 2012 02:08 PM
Redully
Apr 11, 2012 10:49 PM
John Caro
Oct 26, 2009 04:59 PM
fordinmudd
Electrical Systems/Wiring
23
Aug 3, 2006 10:41 AM
