351w Intake Question
Old Jun 25, 2005 | 01:10 PM
onion's Avatar
onion
Exclamation 351w Intake Question
I Have An 1985 351w And I Am Tring To Figure Out What This Port Is On The Side Of My Four Main Intkae Ports It Is On The Passanger Side Of The Intake And Is About 1" Long And 1/4" Wide. It Would Be Under The Erg Valve Plate If I Had One. Also If You Know What It Is Can You Tell Me If I Can Block It Off Since My Carb Covers It Up.
Old Jun 25, 2005 | 10:26 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
If you are talking about the one on the carb mounting surface,its the egr
passage I always
use a carb gasket to block it off in the past.worked good for me, but I used
to make sure that I blocked my egr passages in the back of the heads when
I had engines out!
fox3698
Apr 4, 2011 02:36 PM
i-w
Dec 22, 2010 06:37 PM
Redneck1465
13
Apr 3, 2009 10:33 AM
billybob_81067
Oct 7, 2006 10:16 PM
matt77F2504x4
Jul 27, 2004 07:47 PM
