Difference between HO and non HO EFI intake?
Old Jun 24, 2005 | 12:06 AM
ford5.8's Avatar
ford5.8
I have a friend with a 88 302HO EFI out of a lincoln..Could I put that HO intake on a 94 F150 302? Would it flow any more? Thanks
Old Jun 24, 2005 | 10:59 AM
Kemicalburns's Avatar
Kemicalburns
that intake is for upper rpm power. it may see some gains but they would be small. look into a gt40 intake out of an explorer or cobra if you want to upgrade. or the edelbrock truck efi intake is really sweet for a truck
Old Jun 24, 2005 | 11:18 PM
Artistictouch's Avatar
Artistictouch
Stick with the edelbrock truck intake. Those other possible junk yard HO or Cobra intakes require a great deal of modification the make it work on the truck. If you count your time in the upgrade, it is worth spending the 400-500 bucks for the edelbrock as it utilized the same overall design of throttle body location etc. and is basically a direct bolt on item comparitively speaking.
Old Jun 26, 2005 | 12:07 AM
grampztoyz351's Avatar
grampztoyz351
I've been workin on my '94 putin in a h.o. and I've had to build cable brackets for it,I also had to get a 1" spacer to clear the fuel rails,and move plugs around,by the way i flipped the plenum 180 degrees to clear heater box and I DON'T have a/c on my truck.
