80's sliding glass window in 73 F100
although if you find one in a truck with a good seal... grab a buddie, and a few flat screw drivers. Start on one of the lower corners and from under the seal inside the truck pry up the seal till you see the metal lip that the window actually sits on. then take the second screw driver and use it to hold the seal up by pressing it between the seal and the metal lip. Repeat this process all the way around the lower edge of the seal. The window will start coming out have the buddie on the outside of the truck to hold the window from crashing and breaking.
Really simple to do .. just take your time.. dont try to push the window out without prying the seal... you will bend the metal frame of the slider, and possibley break the glass.
To put the window back in ...
grabe some cloths line rope from your local hardware store... you want a rope that is smooth... Soak the rope in soapy water for just a few minutes.. then push the rope into the seal of your donor window. Start again at one of the lower corners.
Then ... Grab a buddie... and put the window in the cab. you want to put the top part of the widow in the groove. Then At the bottom Start pulling the rope making sure the seal starts to wrap around the metal lip of the cab. Keep pulling the rope while the "buddie" pushes on the outside of the window seal area. Simple...
I have this process down .. I can do it by my self... but for the first timers I suggest a buddie!!!!
Good luck
Good luck
Originally Posted by seventyseven250
What's the process for getting one of these windows out of a truck? The seals on mine look pretty bad, so I'll have to get it all from the donor truck.
f100frank
10-23-2010 01:52 AM
80F100
04-06-2004 08:56 PM
