Rear Differential fluid
Old Jun 24, 2005 | 10:53 AM
Pickupman2004's Avatar
Pickupman2004
I thought I read this on here before, but I couldn't quickly find it when I did a search. How often does our rear differential fluid need to be changed? I have an 04 model. I thought I read somewhere 100,000 miles.....but I thought I remembered it more like every 30,000 on my old 2000 F250.
Old Jun 24, 2005 | 11:14 AM
LOOnatic's Avatar
LOOnatic
Off hand its some wacky high level.
I'm the type that at every 20-30K i change it all but i do tow alot.
I have a hard believing that hot oil can stay consistant over that many miles and heat cycles.
By the way, is everybody's paint cooked off like on my diff. cover?
Old Jun 24, 2005 | 12:07 PM
wolffee's Avatar
wolffee
I know there was no paint on my rear diff before i hit it with the spary paint at 36k..I sprayed almost everything underneath with a nice black paint makes it look SOOOO much better and its cheap just watch that over spray....:-)
ryan
Old Jun 24, 2005 | 12:16 PM
Pickupman2004
The Ford dealer just called and confirmed what I told them I remembered reading.........why did I know this information and they didn't.
Old Jun 24, 2005 | 02:36 PM
jackofalltrades's Avatar
jackofalltrades
You might want to register at https://myford.fordvehicles.com. Within that site there's a PDF download for the complete maintenance schedule for any given Ford. It's some 47 pages with check off lists for each mileage interval.
Old Jun 24, 2005 | 08:49 PM
barnbridge's Avatar
barnbridge
Originally Posted by jackofalltrades
You might want to register at https://myford.fordvehicles.com. Within that site there's a PDF download for the complete maintenance schedule for any given Ford. It's some 47 pages with check off lists for each mileage interval. -Steve
Link doesn't seem to be working.
Old Jun 27, 2005 | 10:21 AM
jackofalltrades
Cut and paste what's between the quotes.
" https://myford.fordvehicles.com "
The website works fine.
Old Jun 28, 2005 | 01:32 PM
The Man's Avatar
The Man
Does it matter how much Fluid you axle can hold? Mine holds 8qts vs the stock 3 or 4 with the Mag hitec..The diff stays at about 130degrees constantly. So does running temp and oil quanity judge how often it needs changed?
Old Jun 28, 2005 | 01:35 PM
LOOnatic's Avatar
LOOnatic
The Man: I'm curious as to how you are monitoring your diff. temp?
You using a pyro gun when you pull over or something?
I idn't know that the MagHyTec pan held that much more oil. Thats a lot.
Old Jun 28, 2005 | 01:53 PM
The Man's Avatar
The Man
I have a Diff temp gague... The instructions say that the D80 MagHytec holds 8, But im in the middle of the filler at 7qts because i ran out of fluid It will hold almost another qt..
Old Jun 28, 2005 | 01:59 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
What kind of temperature fluctuations are you seeing under different conditions on the rear diff?
Old Jun 28, 2005 | 02:10 PM
The Man's Avatar
The Man
Ive had it up to 170 with a 24ft enclosed hooked up on a 1.5hr trip in the hills..
Seems to stay appx 120-140 in town, Takes forever to heat up to that..
It dosnt seem to move all that much, The new Pan keep it very cool..
Texas Bob
Oct 19, 2019 12:12 AM
daveplot
Jun 27, 2011 12:05 PM
old farmer
Jun 12, 2011 11:10 PM
JFUSION
Escape & Escape Hybrid
Mar 19, 2008 12:50 PM
ponch37300
Apr 12, 2007 11:27 AM
