Distributor module
Old Aug 23, 1999 | 09:15 AM
264422's Avatar
264422
Distributor module
I have a 1985 Bronco 2 with the spineless 2.8 and a distributor module that fails without warning. We have replaced the module and distributor...all to no avail. We have bypassed the harness and performed every test that we can think of...again to no avail. The local Ford mechanics just shake their heads.
There are no after market products attached to the system and everything electrical is original. If any of you are aware of this module problem and know of a cure...I'm all ears!
Thanks,
George Haskett
Old Aug 23, 1999 | 10:30 AM
Roger Lane
Guest
Posts: n/a
Distributor module
I had the same problem on an 84 F150. Replaced the module several times. It turned out to be the pickup stator in the dist. itself. $14 from local parts store, about 2 hours labor.
Old Aug 23, 1999 | 12:27 PM
bryan_1's Avatar
bryan_1
Distributor module
I had a similar problem on my f150. It just died at the lights and after towing it home I brought the module to my parts guy who has a tested and it was cooked. After replacing it, still no spark, check the coil resistance and it was fine but went ahead and replaced it as well after reading about a similar problem here on the list.
Hope this helps.
Bryan
Old Aug 23, 1999 | 05:41 PM
murf's Avatar
murf
Distributor module
Jordan901
Jun 19, 2009 12:09 AM
tapia2431
Aerostar
21
May 7, 2007 08:18 AM
George Harms
1978 - 1996 Big Bronco
Mar 26, 2007 05:39 PM
1972 Ford Thunderbird 429 V8
Nov 16, 2002 11:26 AM
264422
Bronco II
Aug 7, 2000 09:25 AM
