1978 - 1996 Big Bronco
1985 Bronco
Old Mar 26, 2007 | 08:53 AM
George Harms's Avatar
George Harms
1985 Bronco
My Bronco runs great for a while, then starts to cough, sputter and dies. I have replaced the motor, the carbuerator, fuel pump, distributor, ignition module, coil,cap, rotor, fuel filter, plugs & wires. I am ready to trash it but my wife really loves it. Help!
Old Mar 26, 2007 | 11:27 AM
scurbiedog's Avatar
scurbiedog
Is it running hot?
Old Mar 26, 2007 | 12:35 PM
andym's Avatar
andym
We need LOTS more info. What engine? How long has it been doing this? Did any of the repairs make it better?
You replaced the *motor*?
Old Mar 26, 2007 | 01:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Assuming you bought a used complete engine from a junkyard, did you swap over all the smog related parts from your old engine, or use the onboard computer that was used with the truck that the engine came with?
Everything today (after 1979 on cars, after 1980 on trucks & E-vans) depends on calibration codes. When buying a used engine, it IS imperitive to get the computer that went with the engine originally. There are over 700 different calibration codes used in the 1980's. It's very difficult to get even one piece of smog equipment without the calibration code. Swap in another engine without swapping the smog crappola, or swapping computers is a nightmare in the making!
Old Mar 26, 2007 | 05:39 PM
George Harms
Thanks for the input. I will check this
1sscav
May 8, 2015 09:51 AM
fordinmudd
Jun 24, 2009 12:03 PM
den7bronco1
Jan 25, 2009 10:46 PM
pdrhodes1
1966 - 1977 Early Broncos
Nov 11, 2006 12:42 AM
