Bronco II Ford Bronco II
85 Bronco ign module
Old Aug 20, 1999 | 09:55 PM
264422's Avatar
264422
I have a 85 2.8 Bronco and the distributor module keeps failing for no reason. The wiring has never been tampered with and there are no after market products tied into the system. We have done every diagnostic possible...to no avail. We have bypassed the harness, etc...all to no avail. The module and distributor have been replaced and the problem still exists. The Ford dealer employees haven't a clue.
If any of you have a better idea please let me know.
Thanks,
George
Old Jun 14, 2000 | 12:49 PM
redbronco2's Avatar
redbronco2
Have you tested the stator assembly?
Old Aug 3, 2000 | 08:05 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Just a thought. When module was replaced, was dielectric grease used on back of it? If not, module will overheat and fail. Grease should also be used in connector to prevent moisture from corroding contacts. A friend's 87 failed after sitting in the rain for 2 days. Good luck. Don
Old Aug 4, 2000 | 03:50 PM
deleontow's Avatar
deleontow
Another item that will cause electrical problems in the dist are poor body grounds. If you have a bad body ground you will get feed back through the gauges and the ingnition causing premature failure. Check all ground conections and ensure they are good and clean.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Aug 7, 2000 | 09:25 AM
Avanti's Avatar
Avanti
shawn.insall
Jan 27, 2010 01:51 PM
tapia2431
Aerostar
21
May 7, 2007 08:18 AM
George Harms
1978 - 1996 Big Bronco
Mar 26, 2007 05:39 PM
Johnboy_BoomerSooner
Jan 7, 2004 10:08 AM
264422
Aug 23, 1999 05:41 PM
