Swapping the TFI-ICM
Tried this over in the truck forum, only one response, so I'll try here.
I've got an '88 2x4 Lariat XLT with a 302. I'm tired of changing the distributor mounted ICM. I've got a heat sink and module from a T-Bird (don't know the year) and have mounted the heatsink behind the grill. Here's the first question. The dizzy mounted ICM has three prongs that go into the dizzy housing, the heat sink mounted one doesn't. Do I have to change the dizzy to match the heat sink module, or does the heat sink module compensate for these prongs? Second question. When I splice the wires, are the positions the same for both modules? Third. Some of the wires are wrapped with foil tape, will I have to rewrap my new harness with the same stuff (it has a wire mesh in it. For RFI?)? Thanks in advance.
macmillanracing
05-29-2011 01:28 AM
cliffrwarren
08-03-2005 09:56 AM
TBloggins
06-19-2005 01:28 PM
