Sponsored by: Kumho
problem with brakes
Old Jun 20, 2005 | 09:59 PM
dontwantogrowup's Avatar
dontwantogrowup
problem with brakes
i have to pump the brakes on my 94 f150. I just replaced the master cylender, bleed all the lines and am still having the same problem. oh yeah i hear a noise sorta like a "whooo" when i am pushing the pedeal to the floor while in driving.
Old Jun 20, 2005 | 10:16 PM
quicklook2's Avatar
quicklook2
stop driving this truck until you find what is wrong.
rebleed brakes. did you bench beed master cylinder?
Old Jun 21, 2005 | 07:22 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome dontwantogrowup, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 21, 2005 | 07:57 AM
MRL123's Avatar
MRL123
Don't drive this truck any more until you fix the problem(s). Re bleed the entire system starting with the psgr. rear and ending up at the drivers front. Did you bleed the master cylinder properly? I like to use a "mighty vac" to bleed the brake lines since it keeps the operation simple.
Let us know how you make out with your repairs.
Cheers
Mike
Old Jun 21, 2005 | 05:30 PM
dontwantogrowup
I took it in to the shop today waiting to see how much thay charge me, and what the problem is.
Old Jun 21, 2005 | 10:25 PM
7700Rob's Avatar
7700Rob
Whatever they charge, will surely be less than the consequences. Rob
Old Jul 7, 2005 | 07:50 PM
LONEPINERON's Avatar
LONEPINERON
So what did you find. from your first post almost sounds like BO power booster or not bled corect.
Old Jul 14, 2005 | 12:55 PM
1975Ford's Avatar
1975Ford
It probably and incorrect bleed of the master cylinder or a faulty power booster which is mounted on the firewall.
DLGries
1983 - 2012 Ranger & B-Series
Mar 22, 2024 08:02 PM
burghard7
May 30, 2013 07:02 PM
galaxie521
Bronco II
May 3, 2013 11:58 PM
rungunner
May 6, 2011 07:54 PM
94FSuperDuty
Dec 3, 2005 11:15 PM
