Brake booster
Old May 6, 2011 | 04:33 PM
rungunner's Avatar
rungunner
Brake booster
Ok guys heres another problem I am having. I had hard brakes and changed the brake booster and pump and now have good brakes. The only problem is that I have to press on the brake pedal really hard to shift the truck into drive. My daughter drives the truck allot and cannot press on the pedal hard enough to shift it into drive. all the vacumn hoses are good. any help would be appreciated.
Old May 6, 2011 | 05:52 PM
Cuda_jim's Avatar
Cuda_jim
The items you replaced do not have anything to do with this problem. The Brake Interlock Switch, BIS, is not being activated when the pedal is pressed or the BIS solenoid needs adjusting or replacement. It's on the bottom of the steering column (see pict below). The brake light switch activates the BIS.....make sure your brake lights are coming on when the pedal is pressed. The Brake light switch may need adjustment.
Old May 6, 2011 | 07:12 PM
rungunner's Avatar
rungunner
Switch
Cudau Jim you are my hero, it was the switch and now I can let my daughter have the truck and I get my new fusion.
Thank you
Old May 6, 2011 | 07:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thank you
Yes he is the man!. I didnt know of the existence of that switch
I tried to rep him but: NO dice.
trevorrules
Mar 13, 2017 07:47 AM
norust
Nov 17, 2016 09:20 PM
1978f250cummins
Sep 19, 2016 07:21 AM
wiltshire46
Oct 6, 2015 06:19 PM
Nealcrenshaw
Jan 23, 2015 05:31 PM
