Help! 82 E-250 Steering Wander
Old Sep 9, 1999 | 02:21 PM
jmerritt's Avatar
jmerritt
I have a 82 E-250 Club Wagon that has had everything in the front end replaced. This includes the steering gear, power steering pump and hoses, tie rod end, drag link, radius arms and bushings, king pins, even the rag joint between the gear and the steering shaft. However, I still get poor return to center and wander. I have had a full alignment done including caster, and still the problem. I would welcome anyones suggestions and ideas. I am at wits end about this problem.
Old Sep 10, 1999 | 08:18 AM
Phillip Guidry's Avatar
Phillip Guidry
Being that the gear was replaced,check the relationship of the pitman arm to the gear with the wheels poited straight forward.The pitman should rest even with the length of the gear and the frame{in other words,front to back,not a little off center}.If you find this to be wrong,look at the tie rod sleeves and notice if there is unequal spacing of the threads.This will indicate that for sure the gear itself is not centered.Another thing could be the tires as well as air pressure.Pump'um up to the max and re-drive.Also try cross rotating the tires.In the end,you just may want to try a different alignment shop.
Phillip
Old Sep 10, 1999 | 09:09 AM
deleontow's Avatar
deleontow
One other item you may want to check is the front wheel bearings, and make sure there is no play in them.
Dave
Old Sep 10, 1999 | 01:43 PM
JohnM's Avatar
JohnM
FordFETruck
May 14, 2012 10:51 PM
jrod16
Jul 1, 2010 01:20 PM
moonley
24
Apr 8, 2005 12:35 PM
jjjrobley
Dec 15, 2003 02:46 AM
ksg302
Jun 17, 2001 05:41 PM
