installing front marker lights
Old Jun 18, 2005 | 09:10 AM
ale's Avatar
ale
my front marker side lights in a 2001 edge went out. I got the bulbs but cant figure out how to get to the old ones. not enough space for my hands to fit in.
can someone tell me how to do this?
if you can point me to some free online how to manuals that would be great too. thanks.
Old Jun 18, 2005 | 12:28 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 18, 2005 | 06:16 PM
el conquistador's Avatar
el conquistador
your owners manual should tell you. if you dont have one they are online at:
https://www.ford-trucks.com/lc/lc.ph...menuIndex%3D14
Old Jun 18, 2005 | 07:19 PM
Ken00's Avatar
Ken00
SECTION 417-01: Exterior Lighting 2001 Ranger Workshop Manual
REMOVAL AND INSTALLATION
Side Turn Signal Lamp —Bulb
Removal and Installation
When installing a new bulb you must remove the headlamp assembly. Refer to Headlamp Assembly in this section.
Remove the bolts and the side turn signal lamp assembly.
Rotate the side turn signal lamp bulb socket one-eighth of a turn, and pull the bulb socket from the side turn signal lamp assembly.
To install reverse the removal procedure.
Headlamp Assembly
NOTE: Make sure that the headlamp switch and the ignition switch are in the OFF position.
Raise and support the hood.
Pull up on the two retainer pins.
Pull the headlamp assembly forward.
Disconnect the two electrical connectors.
To install, reverse the removal procedure.
If necessary, adjust the headlamps. For additional information, refer to Headlamp Adjustment in this section.
Old Jun 18, 2005 | 08:37 PM
ale's Avatar
ale
thanks. appreciate it. works fine.
What manual did you find that info in? how can I get a copy? any online docs I should know about? im looking for free, as I don't have much money these days.
thanks again.
Old Jun 19, 2005 | 08:09 PM
Ken00's Avatar
Ken00
Thats from my Ford manual.
tuffone
General Diesel Discussion
Oct 26, 2008 07:39 PM
blanes
Jul 25, 2007 07:57 PM
85 F-350CrewCab
Aug 28, 2004 11:29 PM
eigenvector
Mar 6, 2004 02:26 AM
slick78
Mar 17, 2002 07:06 PM
