radius arm question
Old Jun 18, 2005 | 06:36 PM
el conquistador's Avatar
el conquistador
radius arm question
i replaced my shocks in march and in the process of taking the right front shock of, I broke the shock stud on the radius arm. I cut the stud off, drilled it out and put a 5/8" bolt in its place. well, i rotated the tires today and noticed that the hole that the bolt goes through on the bottom was broken. my question is, can I weld the bolt in place on the radius arm or should i get a salvaged one?
Old Jun 18, 2005 | 07:23 PM
Ken00's Avatar
Ken00
I don't see a problem welding it or get a mount from a pre 89 1/2, the design had a bracket bolted to the arm so the bolt/shock was supported on both sides, like a normal shock mount.
Old Jun 18, 2005 | 07:34 PM
Ken00's Avatar
Ken00
It looks like this....
Old Jun 18, 2005 | 10:42 PM
el conquistador
thats good stuff ken. thanks for posting the pic, at least i'll know what to look for. ford should've stuck with that design, it just makes more sense. i'll have to call the salvage yards monday. Thanks again, you're a big help.
Old Jun 18, 2005 | 11:04 PM
el conquistador
hey ken,
I can fabricate a piece like that. could you approximate the thickness of metal used? and Is there a bead rolled into the edge of that bracket all the way around or is it flat?
Old Jun 19, 2005 | 01:07 AM
GaryJ's Avatar
GaryJ
I can't imagine a used radius arm is that much $....but maybe I'm wrong. They aren't that hard to remove/replace either. Check out this site... www.car-part.com
Old Jun 19, 2005 | 08:13 PM
Ken00's Avatar
Ken00
I believe it was made from 3/16 flat steel, two bends.
