Wed nite I ordered a diablo predater from motor haven. I have done alot of research on the subject of a tuner. Besides voiding warrenty if it screws up the truck, which I will take responsibility for, does the tuner take life expectancy away from the engine? I don't drive the truck hard. I just want to get rid of some of the low end lag. I tow a horse trailer on the weekends it's 7500 lbs. I figure I only live once and I might as well enjoy the new beast. It takes less muscle to smile than it does to frown.
If used properly, no. And IMO anyone who tries to claim "yes" to that has either no idea how tuning actually functions, or they are just plain ignorant. Just to be blunt.
And I say this as a "non-fan" of Diablo products, especially for the 6.0, so take it for what you think its worth.
Now, I will say sometimes they do have the inherent capability to amplify an already existing problem such as poorly anchored cylinder heads, ect... but the problem will surface eventually with or without the tuning.
I doubt that PSD will bust the Predator in an open forum...he's got more class than some even dream about.
That said, I have been very happy with mine but, I never took it off the 65 H.P. setting...ever.
Just today however, I restored the original programming in anticipation of participation with the current recall . I have to say that two things stick out immediately.
First and foremost, the loss of 65 H.P is much more apparent and seems to have much more impact than the original gain of 65 H.P.
Secondly, immediately upon start up the smell of diesel fumes was much heavier. Probably was that way pre-programmer.
Is it possible that with a programmer you get a more complete fuel burn? Even @ idle? If this is true then would it be safe to say that a programmer could / would cause less EGR valve soot build up?
kw, I don't know it this has anything to do with your performance indications after going back stock, but what about the learning strategy of the transmission when reset? Could that be the difference in how noticable the performance changed after tuner as apposed to before? Maybe after the learning period has completed you will notice some performance back in stock mode.
Actually, it didn't take long at all for the tranny to relearn the shift strategy. 50 miles round trip of mixed driveing...and wallah. Nice and smooth. Didn't really shift hard in the first place. Not like last year when I first loaded the programmer.
Okay, so I guess you thought of that. I should have known but you never know. Thought I'd throw it out there.
You must just be spoiled after enjoying that tuner eh?
so KW,
Are you saying that the trans shifting was more crisp/firm when you first loaded the tune, and after time that went away??????
(tranny wear?)
curious, not trying to put words in your mouth!
these trannies are hella expensive stock.........not to mention what suncoast or the like would charge!
Not at all...
After loading the programmer the tranny does go thru a new shift strategy "learn" mode. This typically creates a hard shift sensation thru the first 4 - 5 start ups. After the new strategy is learned the shifts are what I would classify as normal. Again, nice and smooth.
You can create hard shifts with a programmer but, I don't recommend it. As you stated mattsf250, these trannies are expensive stock.
I only mentioned the restored shift pattern "learning time line since it was noticeably shorter than last year. Maybe because my driving pattern didn't change. Only the computer shift strategy has changed.
Not unless severly provoked. Thankfully I do believe the days of the tuner wars have since past and such arguments are no longer neccessary.
I simply don't agree with some of the tuning methods used by Diablo in development. But as far as everyday driving, using it is just as healthy as running stock or an SCMT. Both tuners are light years away from the plug-ins.
The "rich diesel stink" will come about any time you flash back to stock. The stock files have to relearn idle air/fuel ratio (occasionally you will get a tune that will do the same thing) , and they will normally run a little rich until the adaptive database has some miles. It will most likely go away.
PSD60LFx4 Thanks for your honest input. I'm not trying to start a tuner war. I just like to learn the facts since I have never used one. I do use a chip in my 91 corvette and it makes a huge difference. I just don't want to screw up my new truck.
Back to the original question, longterm affects of a chip or tuner.
My first PSD was a 95 7.3 F-350 CC LB SRW auto 3.73 gear, had chip as soon as I could get one(at about 18000 miles), towed most of its life with me. Sold truck with 280000 miles on it to by my 03 6.0 PSD. had no engine problems.
I would say if you have good guages and watch what your engine is doing with the tuner it will last a long time.
