FE series question???
I do not want a race car, I want a good reliable engine that is fun to drive. I am only looking for about 300-350hp and around 350-400 ft.lbs.. I know a 390 can do this, but I am curious as to what all can be built, I like to be a little different than the norm.
when you get you a rebuild kit for your 360/390 (which ever way you choose to go) if you are rebuilding it to be a 390 then get a rebuild kit for a 360. the piston will be the higher compression car pistons about 9.5:1 vs the truck 390 pistons at about 8:1
you would have to bore that block .080 to get the same bore a a 428. It can be done when i was checking at my local machine shop he said that it would make the walls to thin and that would not be a very good thing to try.
this is my build for my 390 all parts form summit expect rocker arms and pushrods
rebuild kit FEM-MKP601N-311 (this kit says that it has lifter but it does not come with them) just a FYI
cam and spring CRN-343942
intake EDL-7105
oil pump MEL-M57HV
oil pump drive shaft ARP-154-7902
rod bolts ARP-155-6002
timing chain SUM-G6608
headers WLK-86041
Carter AFB carb
Pushrods from www.DSCmotorsport.com (great place for good parts)
rocker arms from local CarQuest
just to help you out
intake EDL-7105
oil pump MEL-M57HV
headers WLK-86041
Carter AFB carb
if you do go with that crane 343941 cam (cam and lifter kit 343942) i would suggest that you go to www.dscmotorsport.com and get his adjustable valve train kit that he has for about $320. i think it was new pushrods, adjustable rocker arm shaft assembly with solid spacers in between the rocker arms (great deal)
he knows alot about the FE motors
