engine code 135 and 301 "check engine'
Old Jun 15, 2005 | 01:10 AM
billexpedition's Avatar
billexpedition
any thoughts as to how to resolve these codes...any help would be great.
97 ford ranger
bill
Old Jun 15, 2005 | 04:10 AM
AlfredB1979's Avatar
AlfredB1979
P0135 - Bank 1 upstream (only ones that matter) O2 Sensor heater circuit malfunction. Passenger side on a v-engine (where cylinder 1 is) and you have no choice on the I4. Check the wiring to the O2. Someway or another, the computer is not sensing proper operating temp from the O2 sensor. This DOES NOT necessarily mean toss the O2 as some will do "just because".
P0301 - Cylinder 1 misfire. Check the plug, if that's bad, replace 'em all then. If that's not it, check the coil pack. Hopefully, it's not a intake/head gasket leak of some sort fouling things up, but that's what the plug check may indicate.
Engine info would help, since some engines may have quirks that are associated with such issues.
Good lcuk.
Bearpaw357
2004 - 2008 F150
Jun 9, 2012 09:20 PM
jkidd_39
Jan 30, 2009 07:50 PM
99fordf350coding
Apr 22, 2007 10:42 AM
paradiddle
Electrical Systems/Wiring
Feb 9, 2004 11:30 AM
ktm520mxc
Computer Chips & Tuners
Aug 3, 2003 09:06 AM
