IDM Code P01316?
Old Jan 30, 2009 | 05:15 PM
jkidd_39's Avatar
jkidd_39
IDM Code P01316?
My IDM Box was going out.. sending codes that injector circuits were staying open and such.
I ordered a reman IDM box and all my PCM codes are gone and the IDM box is not sending any codes to the PCM..
But it is storing code P01316. So my check engine light is staying on.
Any way to clear out the IDM box?
The company offered to send another but I really don't feel like tearing into the fender again if I can clear these codes.
Thanks alot guys
Old Jan 30, 2009 | 05:20 PM
ron's power stroke's Avatar
ron's power stroke
no you cant...it can be re built.. but your better off waiting for the other one to come...
Old Jan 30, 2009 | 05:35 PM
jkidd_39's Avatar
jkidd_39
Thats what I figured. Thanks Ron
Old Jan 30, 2009 | 06:05 PM
Action4478's Avatar
Action4478
Thanks alot guys
Have you checked the UVCH 's for burned or loose connections?....
Old Jan 30, 2009 | 06:12 PM
ron's power stroke
what he said ^^^^....I answered your question without thinking if there was another solution...nice Rick..
Old Jan 30, 2009 | 06:41 PM
clintbonnie's Avatar
clintbonnie
The first thing I would check is for a loose connector under the valve cover... Thats exactly what i found with a P1316 and SES light.. You might it fixed for only 50 cents.. ( two quarters as shims for the poor locking tabs)
Old Jan 30, 2009 | 07:50 PM
F350-6's Avatar
F350-6
Is your truck still running bad, or do you just have a left over check engine light from your old problem? I agree that the most common cause for the P1316 is a loose UVCH connector (the IDM may not have been needed), but if the new IDM fixed all your problems except for the CEL, then just disconnect both batteries for a while. That will clear the dash light.
OMAHACORESUPPLY27
Oct 5, 2020 06:51 PM
OldWoodsDiesel
37
Jan 13, 2020 11:53 PM
blrman1962
Dec 11, 2016 10:42 AM
noober0x
Sep 13, 2016 07:17 PM
z31freakify
Jul 12, 2016 12:48 AM
