Offroad & 4x4
Help Settle an Argument
Old Jun 21, 2005 | 08:41 PM
  #61
proeliator's Avatar
proeliator
Hmmm, better just use an svo alum block while I'm at it. Then I'll be saying anything less than 600 cubic inches is for wussies Remind me to make you one of my famous rum and cokes at the national. I'm sure Ivan agrees that they're fantastic. I know fez does.
Old Jun 21, 2005 | 09:20 PM
  #62
monsterbaby's Avatar
monsterbaby
Now that is a good idea, then that definatly fit's into the have the cake and eat it too. 600+ CID, and weigh less than a V6 can't hardly beat that.I ain't sure I would let you touch anything I am drinking remember I am subject to random drug testing at work, and am not sure I could pass after that
Old Jun 21, 2005 | 11:35 PM
  #63
mustange70's Avatar
mustange70
Dang, you must've changed your old sig right after posting that rob .
Old Jun 22, 2005 | 07:34 AM
  #64
cleatus12r's Avatar
cleatus12r
Butt-Head
I think he changed his sig because some dude over at Pirate was telling him that he didn't know anything about building trucks........Unless someone over here told him that he was an idiot, but I think we all know better than that.
Cody
Old Jun 22, 2005 | 04:47 PM
  #65
mustange70's Avatar
mustange70
Yeah thats what i figured, but it just happened right in sequence with that post of his on the other page .
Old Jun 22, 2005 | 09:09 PM
  #66
Saurian's Avatar
Saurian
I know better, he might try to run me over when I go see him run in the mud.
How much does the SVO block weigh, and cost?
Old Jun 22, 2005 | 10:02 PM
  #67
mustange70's Avatar
mustange70
I'd be more owrried about the cost in that aspect .
Old Jun 23, 2005 | 01:18 AM
  #68
monsterbaby
If your talking about the motorsport A460 iron blocks they are around 50-60lbs heavier than a passenger car block and the eliminator blocks weigh around 280 if I remember correctly which is 60lbs also. but if you are meaning the AR alum boss 9 block about the same amount lighter.
Old Jun 23, 2005 | 09:34 AM
  #69
Saurian's Avatar
Saurian
I was referring to the Aluminum, or was it the A460 that could be taken out well over 600 cubes?
Old Jun 23, 2005 | 11:17 AM
  #70
ivanribic's Avatar
ivanribic
$5000 sure seems like a LOT of money to spend so you can save 60 pounds. A460 and the Eliminator can be punched over 600 cubes as well as the aluminum block. I believe they allow up to a 4.7" bore so with a 4.5" stroke you're at around 625 cubes. Of course this doesn't leave you any room for error or a work on the cylinders if you rebuild so you'd probably cut that back to a measley 604ci.
Old Jun 23, 2005 | 01:28 PM
  #71
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
im running lightweight sparkplugs and i shaved my oil dipstick
i consider her to be lightweight
ive been thinking of dropping in a bored and stroked 2.xL beattle motor in to save some weight, 250 lbs and about 150 horses, that should cut my times in half
Old Jun 23, 2005 | 01:34 PM
  #72
monsterbaby
I just take a healthy dose of Phillips M.O.M. the night before a race by the time it time to race it's amazing how much weight you save.
Old Jun 23, 2005 | 03:19 PM
  #73
ivanribic's Avatar
ivanribic
And all this time I thought it was mud you had all over your truck.
Old Jun 23, 2005 | 06:02 PM
  #74
KubotaOrange76
i didnt want to think about that
Old Jun 23, 2005 | 06:14 PM
  #75
NickFordMan's Avatar
NickFordMan
ooohhhhh!!!!! jeez....that reminds me of the Steve-O video I saw last night....lets just say it was messy....
