IGNITION PROBLEM
Old Nov 10, 1999 | 11:03 AM
DARYE's Avatar
DARYE
IGNITION PROBLEM
I HAVE A 89 F-150 W/300. RECENTLY MY IGNITION ON THE COLUMN WENT BAD AND I HAVE BEEN STARTING IT WITH A SCREWDRIVER ACROSS THE SELONOID. BEFORE I ATTEMPT TO REPAIR THE SWITCH IS THERE ANY SPECIAL TOOLS I MIGHT NEED TO REMOVE THE COLUMN OR THE SWITCH ITSELF? MANUAL TRANSMISSION WITH CRUISE ON TH STEERING WHEEL, & TILT.
Old Nov 10, 1999 | 12:22 PM
Mulletwagon's Avatar
Mulletwagon
IGNITION PROBLEM
89 F-150s, Broncos, and Mustangs were recalled about two years ago for an ignition switch change at Ford's expense. The hot pole on the switch was too close to ground and had a history of shorting and starting fires. Local dealer changed mine out (Bronco and Mustang). Switch is located on the column below dash. HTH
Old Nov 10, 1999 | 04:30 PM
Pastmaster's Avatar
Pastmaster
IGNITION PROBLEM
I had to replace my ignition switch on my 89, and I got a Ford switch, but I had to pay for it, does ford have to pay for this? Maybe I should get my money back?
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Nov 10, 1999 | 07:17 PM
Hdlinerman
Guest
Posts: n/a
IGNITION PROBLEM
Pastmaster, try going to www.nhtsa.dot.gov under the car safety column go into problems and issues and then enter into the recall section. This should answer your question
Old Nov 10, 1999 | 11:06 PM
Superdave's Avatar
Superdave
IGNITION PROBLEM
ungerp
Nov 26, 2012 10:10 AM
Bullettooth94f150
Aug 12, 2008 07:25 PM
ranh
Dec 7, 2006 11:14 AM
aerodam
Aerostar
Feb 21, 2006 09:48 PM
mirrormaker
Aug 21, 2003 12:06 PM
