squeaky clutch
Old Oct 27, 1999 | 04:42 PM
jimbob537's Avatar
jimbob537
squeaky clutch
i have a 1995 f150 3/4 pickup. my clutch is squeaking. what can i do. heard i should lubricate
pivot head. dont know how to get to it. help please
Old Nov 1, 1999 | 09:25 PM
mholota's Avatar
mholota
squeaky clutch
Grab a can of WD-40 and put your head under the dash. Move the clutch pedal with your hand and spray wherever you see something move.
Go under the hood and do the same. this should do the trick.
Still not fixed? Go under the truck and spray the linkage.
Your problem should be fixed. If not, turn up the CD player and don't worry about the noise from the clutch.
Old Nov 11, 1999 | 12:56 AM
Nate's Avatar
Nate
squeaky clutch
Hows the pedal feel?
Can you feel the "squeak" in the pedal travel?
Get under the truck.
Have a helper operate the clutch (engine not started) and see if the noise comes from around the transmission bellhousing.
If so, you have a bad slave cylinder or throughout bearing.
Old Nov 11, 1999 | 10:29 PM
rick's Avatar
rick
squeaky clutch
